So what's is a mid level improvement for stock headlights?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
I got dapper LEDs for my birthday.
Pricey but work well with the stock sockets. So many deert where I live, I need to see.
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
I am assuming that mid-level refers to price.
With the base being OE T3's. The next step would be Halogen sealed beam replacements. $15-$20 (Most parts stores) After that would be the Toyota Land Cruiser replacements with H4 bulbs. $20 (Toyota dealers)(Photos below) Probably the best bang for the buck but, they do require you to modify the headlight buckets. Then Hella or Koito H4. $90-$150 (Daniel Stern or folks like Summit) May or may not require bucket modification. I would avoid any of the LED stuff lights priced under $250 each. Most are poorly engineered, having bad light distribution and short life spans. Above $150 each in my book would be high end.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
I added these to my 76 TA a few years back. Happy with the results and improvement.
I just got the rampage set up ,much brighter and didn't break the bank at 140
| The Following User Says Thank You to 65 Lamnas For This Useful Post: | ||
LED's for mine. Huge improvement in light & less power usage. I have all bulbs in my 73 TA converted to LED's.
Yeah, the lights do get hot.When installing relays do I need two for each side low and high beam?For a total of four.
1 relay for low beams, 1 relay for high beams. Doesn't matter if it's a 2 or 4 headlight system.
OK great,I just finished looking at some wire diagrams for installing relays
