Old 06-02-2025, 10:22 PM
Matt1970gto Matt1970gto is offline
Default Project Pro Port
I received my big port pro ports and my worked BOP intake from BES. Their work looks killer, although my 2.5 year said the intake didn’t look good & needs work. After several phone calls & texts between BES & Scott Brown Scott sent me a pretty sweet little cam for this project . I still need pistons, rings & shaft rockers but am going to finish the season with my dci-5 build.
ID:	652478   Click image for larger version
ID:	652479   Click image for larger version
ID:	652480   Click image for larger version
ID:	652481   Click image for larger version
The Following 7 Users Say Thank You to Matt1970gto For This Useful Post:
Old 06-02-2025, 11:30 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Very nice!
Go fast, see Elvis!
Old 06-07-2025, 09:32 PM
slowbird's Avatar
slowbird slowbird is offline
Really nice! Heads come with shaft rockers or you still need to get those?
Old 06-07-2025, 10:38 PM
Gotta get them & I about shat myself when I saw the prices now. I was telling Paul earlier today I gave like 1200-1300 for the t&d shaft rockers in 2015 & now they’re over $2600.
Old 06-07-2025, 11:31 PM
slowbird's Avatar
Crazy how prices have gotten out of hand. I just looked in 2022 I paid $1980 for a set.
Old 06-08-2025, 12:49 AM
PAUL K's Avatar
And Paul told you where to go to get around that problem
Go fast, see Elvis!
Old 07-08-2025, 01:20 AM
blueghoast's Avatar
Aren't them heads an 11 degree angel ? and any numbers flow wise ?
Sure are some great looking jewlry there.
GT
Old 07-08-2025, 06:56 AM
GT
Yes to the 11 degree & not sure about flow numbers . I did ask about flow numbers & got this response
“i did not flow your heads but i can give you flow numbers for those heads”.
Old 03-20-2026, 10:35 PM
Default Finally
Got home this afternoon with project pro port. Engine builder only made 3 dyno pulls and I feel there’s more there but overall it should be a nice piece . It made 1078 hp @ 7200 & 858 ft lb trq @ 5600 with a 1250 get’m carb & a APD throttle stop. First pull timing was @ 35, second was 32 & final was 32.5. Not sure what gas they used but I think fuel factory F14. I also attached my ram air 5 dyno sheet.
ID:	666631   Click image for larger version
ID:	666632   Click image for larger version
ID:	666633   Click image for larger version
The Following 6 Users Say Thank You to Matt1970gto For This Useful Post:
Old 03-20-2026, 11:23 PM
PAUL K's Avatar
Great job! Thanks for sharing
Go fast, see Elvis!
Old 03-21-2026, 07:12 AM
performerrpm's Avatar
performerrpm performerrpm is online now
dang ...you exceeding my power adder goals with an na motor...i bet thats gonna be a handful
Old 03-21-2026, 10:50 AM
Stan Weiss's Avatar
Matt,
Congratulation that is a huge increase in mid range power.
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 03-21-2026, 04:01 PM
Gary H's Avatar
Gary H Gary H is offline
Very nice! What cubic inches, and what compression ratio?
Old 03-21-2026, 04:12 PM
571 c.i. & 15.1
The ram air 5 set up was 15.5 & same cubic inch
Old 03-21-2026, 09:56 PM
Matt,
Stan
Thanks Stan.
I figured the average hp between 6500-7500 with this combo vs my dci5’s & dad’s dci 5 as well. Pretty happy with the numbers since the pro port had the highest average. Can’t wait to get it on the track. I’ve talked to my converter guy & he wants to start with the same converter I ran with my 5’s. Trying to make it an even playing field to see what real life track data shows.
The Following User Says Thank You to Matt1970gto For This Useful Post:
Old 03-22-2026, 06:56 PM
aaronman aaronman is offline
Congratulations to all involved. Making this type of power at this lower rpm shows how much more efficient this combination will be! Can’t wait to hear your on track results!
Old 03-23-2026, 08:49 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Paul, where do we go to get around the problem? I'd love to know too. Thank you Sir!
69 Firebird - Angry Bird
455 with 84mm Torqstorm
Old 07-19-2026, 09:52 PM
Default Pro porr
I took the car to a local track about a month ago & went 5.34 @ 130 w/1.20 60 ft in 3400 ft air. It won’t let me upload the video here but the converter was too tight , lazy coming up & lazy down track. Just got the converter back in & was hoping to try it last night but the rain won.
The Following 4 Users Say Thank You to Matt1970gto For This Useful Post:
Old 07-19-2026, 11:35 PM
PAUL K's Avatar
Thanks for the update
Go fast, see Elvis!
