How much voltage is your charging system outputting when the fan is on?
Voltmeter reads near 14
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching 1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching 1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th) 1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching 1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching |
A higher flowing fan would probably get temps under control while stationary and low speeds. With an iron headed, iron block engine, it takes a little more cooling to keep the temperature down. Some of the newer OEM fans have "trap doors" that open from airflow through the radiator at higher speeds when airflow exceeds what the fan can move, it's possible that higher CFM fans could help drop temps a couple of degrees during a pass.
I'd try a different shroud than that one? One like the original style to funnel the air through? Also is the fan made to blow through or suck the air?
To me it looks like a restriction to air flow.
| The Following User Says Thank You to dv657172 For This Useful Post: | ||
I use a Mark VIII fan that has it's own shroud and works very well in keeping my car cool with a meziere water pump. My temps typically go up 10-15 degrees at the end of a quarter mile up to about 190-195 F. I also use a Griffin ali radiator.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
I hate electric fans and agree with post 24.
These fans are mounted too close to the radiators due to the shroud’s being too shallow . Look at it this way. If the OEM shroud set up could have been made 3 to 4 inches shallower and still provide adequate cooling , then Pontiac would have gone for that savings in plastic of making a shroud. Fan efficiency drops off pretty fast as a fan is moved closer to the radiator and since fans are round and radiators are rectangular a close mounted fan does not even pull any air through about 8 or so square inches of the average size radiator in a A body car.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
| The Following User Says Thank You to ta man For This Useful Post: | ||
Seeing a lot of positive comments on the Mark VIII fans.
I was wondering if the tightness of the shroud was an issue but I didnt realize a fan could be too close to a radiator, steve25. AG/taman - possible to see a pic of your setup? Thanks DV
You need to check your water pump plate in the timing cover and in particular the rubber steel cased bushing behind it.
Many times new bushings are not tall enough to actually seal like they should on the rear side of this plate. Placing a round shim spacer under the byshing will get rid of that leaky gap that should not be there. In my photo here these washers used as spacers can be had from McMaster Carr supply. I could not load the photo even after waiting 4 minutes, so here’s the part number for a pack of ten, 25237.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 03-31-2026 at 03:51 PM. Reason: . |
I'll try to get this weekend. Need someone to help take the hood off since it's under the lift.
AG - thanks but if its too much trouble I understand
steve25 - car runs a Meziere Heavy Duty Electric WP so I dont think that is applicable (correct?) but good info for my other cars
I don’t know if that pump still requires the usage of that separator plate.
If you can see the pump veins then it would have to use the factory plate , and if that’s so then that pump vein to plate clearance needs to get checked and reset if it’s too great. Ideally you do not want more then .025” pump vein to plate clearance needs. Don’t forget that the front gasket adds clearance, so really the plate needs to be touching the veins with no gasket in place.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 04-01-2026 at 08:36 AM. |
Here are the pics of the Mark VIII fan. I use a 75 amp relay for it.
AG & ta man - thanks for the pics and info, much appreciated!
Super custom gold anodized wire separators for the shroud mounting up top.
#38
What are you running running for a intake manifold?
#39
Get rid of that restrictor and install a 160 * Napa stainless thermostat. Have your fans running when engine is up to temperature. Remember that the thermostat will be fully open around the 160* to 165* mark. I also drill a 1/8" hole in the thermostat for a bypass.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
#40
steve25 - Torker II
chuckies76a - why on the thermostat vs. water restrictor? How would that help any? Thermostat is basically only useful for warming up a cold engine quicker. Doesnt help in cooling one. Once its open its open and its not fully open until 10-15 degrees after the rating temp. At least thats my understanding Fan and water pump can be controlled manually and are turned on as soon as car can idle on its own (generally about 125 degrees) plus I have a temp sensor that turns them on at 185 dgrees if I havent already for safetys sake.
