1967 4 BARREL MANIFOLD SET
(These will fit & function on all OHC 6 Engines with proper carb gaskets) FULLY FUNCTIONAL HEAT CONTROL VALVE. EXHAUST MAN HAS 1 CHIPPED MOUNT HOLE. I WILL INCLUDE NEW MOUNTING GASKETS. YOU WILL NEED HARDWARE. $250 obo + SHIPPING (SHIPPING IS NOT INCLUDED) I can assist with shipping. Buyer can pick up or handles all logistics and payments. VA BCH VA.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
Yes, this will fit '69. Thx
Jeff - being new to the OHC community, I have a question. Will the intake bolt up independently of the exhaust manifold? I have 6-into-2 headers and want to retain that but prefer the 4-barrel over the current Weber setup. I can probably pick up in person too. My brother lives in Chesapeake and I get over that way often.
| The Following User Says Thank You to scotty54 For This Useful Post: | ||
Yes the intake will work with headers, but you may have to make some odd spacers to account for any differences in the thickness of the flange used on the headers, compared to the thickness of the stock intake. I don's know how thick the header flange is on your headers, or how the previous owner mounted the webber intake with the headers, pictures would help. The issue may already be solved, and you may just be able to reuse what is currently on the car.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
| The Following User Says Thank You to camerjeff For This Useful Post: | ||
As Jeff mentioned, The header(s) can be used with factory intakes and may require offset/stepped retaining washers.
Some of our club members said they were able to mount them using stock washers, but I think the offset give you a better bite. ![]()
I attached a photo.
I would like to buy the set. Like I said, I can pick up sometime in the next month or so if that's okay. Please call or text me at 904-553-9526 and I can arrange payment. |
Sounds Good. I'll reach out this weekend.
... decided to through them in the box and lighten them a bit.
SOLD. Thanks Scotty!
