Old 03-02-2026, 05:11 PM
64-389's Avatar
64-389 64-389 is offline
Default 63 Tri-Power HELP!
Hey Guys,
I recently purchased a 63 Tri-power setup and would like to identify all the pieces I need. It came in pieces and with 5 extra carbs.
The 2 dumps were easy to find, but there's 6 "Center Carbs" and I don't know if any of them are correct. Please see photos and see if you see the correct one, or one I can use.
I'm not concerned with matching numbers or anything like that. Just need to know how to proceed from here.
Thanks!!
ID:	665742   Click image for larger version
Name:	Manifold & Dumps.jpg
ID:	665743   Click image for larger version
Name:	Center Carb 1.jpg
ID:	665744   Click image for larger version
Name:	Center Carb 2.jpg
ID:	665745   Click image for larger version
Name:	Center Carb 3.jpg
Tom
1964 GTO Custom Convertible
Old 03-02-2026, 05:12 PM
64-389's Avatar
More Carbs....
Name:	Center Carb 4.jpg
ID:	665747   Click image for larger version
Name:	Center Carb 5.jpg
ID:	665748   Click image for larger version
Name:	Center Carb 6.jpg
Tom
Old 03-02-2026, 06:43 PM
pfilean's Avatar
pfilean pfilean is offline
you need to get casting numbers and check information that is available with searches here. But from what I see in the pictures a 63 will have the auto choke without the tube in the stat center, will not have that big filter in the fuel inlet and will not have that little umbrella vent cover.
Old 03-02-2026, 06:58 PM
gtoguys gtoguys is offline
From the pictures I see, the one that has the stainless steel vent cover on top, appears to be the correct center carb. The other carbs look like chevy. The one that has the vent pipe coming out of the choke thermostat is 1959 and older.
Old 03-02-2026, 09:43 PM
64-389's Avatar
Thank you both! That was hugely helpful.
The center carb you guys ID’d has the number 7019927 (photo labeled “Center Carb 2” above) and the 2 dumps have the number 7011997 for both. Based on some research here on the forums, those are like 61 carbs? Should work though right? The plan is to put this on my 64 389.
3 others have vents coming out of the thermostat. Does that mean all 3 of those are 59 & older?
Thanks again!
Tom
Old 03-03-2026, 12:51 AM
Dick Boneske's Avatar
THe 4 of 5 in the first group is the best choice. It is correct for your '63 setup. The 1 of 3 in the second group is correct also but missing the choke housing. The brass Tee fitting on the rear of the base is a key item you''ll need.
The end carbs look correct. Pick the ones in the best condition to restore. You need one with a tapped hole in the rear of the base and one with no hole.
DM me for more info. I can provide pictures, fuel lines, linkage, choke heater tubes, and whatever else you need to complete the Tri-Power. I have three complete '63 setups here, plus any parts you may need.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-03-2026, 12:58 AM
That intake is a '61 or '62. It will work but does not have provision for PCV like '63 Tri-Powers used. You can drill and tap to add PCV to your manifold. I can send pictures to determine location for the 1/8-NPT ports of you need.
Or, if you want a '63 intake manifold, I have several.
BONESTOCK GOATS
Old 03-03-2026, 08:02 AM
Kenth's Avatar
Kenth Kenth is offline
7019927 is used for the 1961-65 M/T center carb.
7011997 is used for the 1959-63 outer carbs.
Your center carbs #2 and #4 looks like genuine Pontiac Tri-Power units.
#4 for 1965 M/T, #2 for 1961-64 both A/T and M/T.
Check this out (thanks Jon at "thecarburetorshop"):
https://www.thecarburetorshop.com/Tripowerspecs.htm
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-03-2026, 09:14 AM
64-389's Avatar
Thank you again guys. Great info! Dick, please expect a DM from me.
Tom
Old 04-10-2026, 01:02 PM
64-389's Avatar
Well, I'm a little beside myself at the moment, but excited to share. My cheapest route was to rebuild this thing myself. Including the carbs. Turned out better than I hoped!
Tomorrow is installation day and I hope it runs well. Thanks again for helping ID everything I had!
I probably used parts from about 6 of the carbs to rebuild these three. And I modified some of the linkage and what not, but all seems to be working fine.
ID:	667995   Click image for larger version
ID:	667996   Click image for larger version
Tom
Old 04-10-2026, 02:43 PM
Hot air pipe to the choke coil should be all steel. It looks like you have a piece of hose on there, dont think that is going to work. Looks good otherwise.
Old 04-10-2026, 03:25 PM
You are correct.
He needs both steel choke tubes for the hot air choke to function. The missing one connects to his air horn with a short section of rubber vacuum hose, this is where the air flow starts to the choke thermostatic spring.
Dick makes and sells the correct tubes.
Pictured below is my 1964 421 HO, carbs restored by Dick along with his fuel lines and choke tubes. He was even able to supply custom choke tubes that were slightly longer to work with my .280” thick phenolic carb spacers. Zoom in to see how the choke tubes should look.
Old 04-18-2026, 05:38 PM
64-389's Avatar
Today was the day!! I had my Dad in the drivers seat and my son on the iPhone. Enjoy!
https://youtu.be/PT1NNrweLHU?si=209SOpM34O1iXq4I
Tom
