Old 05-06-2026, 10:17 AM
Kirill Catalina Kirill Catalina is offline
Default Normal Yoke Play?
Hi there,
Ever since i have my car there's a pretty loud 'Clunk" coming from somewhere in the drivetrain when shifting from park to reverse/drive or drive to reverse. Yesterday i climbed underneath the car to check if i had play in different components and noticed some play in the U-joint and where the yoke slips over the trans shaft. My question now is: Is the amount of yoke play, Radial and up-down, normal or am i facing worn bushings or something? And, could the play in my U-joint generate such a audible and feel-able clunk? Also i noticed there's a crack in the yoke, whoops.. so that one needs to be replaced.
1973 Grand safari
Vid > https://www.youtube.com/watch?v=sPDmNVOOVgk
Old 05-06-2026, 10:33 AM
bill ryder's Avatar
bill ryder bill ryder is offline
there should be no play. If it is noticeable by hand, you have bad u joints,
"Bill"!
Old 05-06-2026, 10:34 AM
"Bill"!
Yes but what about the play at the yoke where in goes into the trans? Should there be some play between the yoke itself and the shaft?
Old 05-06-2026, 11:08 AM
tempest1964's Avatar
Yes there is. The in-out is to compensate for movement as your suspension goes over bumps and such. I can’t quote allowable tolerances for the in out off the top of my head. Hopefully others will chime in. If you do like Bill said and put new u-joints in hopefully you will be ok.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
Old 05-06-2026, 11:27 AM
Thanks! I'm mainly curious about the amount of tolerable radial and up-down play, so when i twist or push the driveshaft assembly upwards so to speak?
Old 05-06-2026, 11:42 AM
The yoke should have no appreciable movement up/down only in or out.
The u-joint may be making it seem like the yoke is what is moving. Are you sure the yoke itself is moving up/down?
You did say it was broken so that would give it movement.
Need to change it and put new u-joint in when doing that.
Try the new yoke on the tranny shaft and see if it works OK.
Old 05-06-2026, 12:05 PM
chiphead's Avatar
chiphead chiphead is online now
Max clearance slip yoke OD to tailshaft bushing ID is .008".
I have a bit of radial slop, and my yoke to tailshaft clearance is .006". This is a new bushing and a fairly new 1350 yoke. The yoke did take a beating when I had the U-joint angles wrong. I have since adjusted the upper arms on the rear end to fix that.
Check U-joints for slop in the caps and rear end for R&P backlash. Put the car in neutral, chock the wheels, Grab the rear end yoke and see if you can turn it back and forth before the gears engage. Do the same thing to the u-joints, looking for slack in the caps.
Old 05-06-2026, 12:07 PM
chiphead's Avatar
I just watched the video. Your front U-joint is worn out. Looks like its dry and likely the needle bearings are fooked.
Old 05-06-2026, 12:21 PM
Will do!
Old 05-06-2026, 12:23 PM
Yeah, needs to be replaced! Think i'll have to bring my torch to the party because i have the feeling it's still the original plastic style piece
Old 05-06-2026, 01:43 PM
During reassembly apply some wheel bearing grease to the trans output shaft splines .
Old 05-06-2026, 02:20 PM
Kenth's Avatar
Kenth Kenth is offline
Grease to the trans output shaft splines only applies with yokes that are sealed at the un-splined end inside by an O-ring on the output shaft.
Yokes w/o this O-ring are lubed by the ATF.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-06-2026, 02:30 PM
True enough!
Old 05-06-2026, 07:48 PM
george kujanski's Avatar
yep, I see the ujoint cup halves move relative to each other.. R&R ujoint.
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 05-07-2026, 05:48 AM
I just watched your video and need to say please do not drive the car at more then 30-35 mph.
If a front U joint let’s go while your driving ( especially down hill) it can jack knife the car when it it digs into the pavement.
Old 05-07-2026, 06:13 AM
Yeah, in the video you can clearly see some movement there. I will be changing the whole chabang, yoke, joints and see if that solves the problem!
Old 05-07-2026, 06:51 AM
When you go to remove the drive shaft jack the ass end of the car way up and you will only loose hardly any trans fluid.
Be sure to chock the front wheels!
Old 05-07-2026, 07:50 AM
Thanks, Will do!
Old 05-07-2026, 03:54 PM
Allright, I pulled the driveshaft. Nothing wrong with the yoke.. It's only a metal edge which looked like a crack in the video I made. I made another video of the output shaft play and rear end / R&P play. I think the noise I'm hearing when shifting is coming from the rear-end.. You can see how much noise this makes when turned. Normal or excessive?
https://youtu.be/gvjtGRlm-FE?is=Vaz9AUcz3z2ovQ43
Old 05-07-2026, 05:12 PM
Looks like the trans needs a new support bearing in the tail shaft section .
The rear could need new spider gears and a crossshaft and or that play could be from the ring & pinion.
Time to pull the cover and have a look.
