Hey Guys,
Where to find a Moderately Priced Flexible and Locking Turbo 400 Dip Stick Tube? Thanks Again. Craig |
If you have a dipstick....
This is what I used https://www.summitracing.com/parts/a...gaAjP0EALw_wcB The only flexible I am familiar with is the Lokar at $200+
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
| The Following User Says Thank You to Mike Davis For This Useful Post: | ||
Interestingly enough, I've found that many TH400 dip stick TUBES don't fit, even ones that are listed for the application. I at one time had a graveyard of tubes/sticks because of this.
If you need the tube and stick, this is the one that I've used on both TH400 & 4L80e, in both 68-72 A-bodies and 2nd gen F-bodies: https://www.summitracing.com/parts/tci-743803 I believe I have used the ATI ones as well, but the TCi one was the first I found in my notes. .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
Hey Guys,
Thanks and I should have said full length 72 gto and flexible. Craig |
The only ones I'm familiar with are the Lokar and Autoloc ones, and IMO, the Lokar end that you trim is kind of sloppy.
It works, and if you're careful, you can make a good end, and will work fine. The Autoloc ones come in different lengths, so you can get one close enough where you don't have to cut them. Last I looked, the Lokar one only comes in 1 length. B&M used to make one, but I've never used them, so can't really comment. Suspect others make them, there too, have only used the Lokar and Autoloc ones. .
ATI makes one for 20 bucks. But no dipstick attached.
I keep one around if tech asks for it. But I keep my stock one on the car with a little zip tie looping around the bracket that bolts to the rear of the head. They let me get away with it but keep the locking one in toolbox just in case. |
| The Following User Says Thank You to Dragncar For This Useful Post: | ||
