Old 05-02-2026, 06:11 PM
GT182's Avatar
GT182 GT182 is offline
I'm working up to changing the control arms on my 66. The bushings are shot for the lower ones. Changing to boxed ones. Upper will be done later to boxed.
Also contemplating on putting in the 421SD with tri-power. And yes. It's period correct for the 66 GTOs but came out of a 66 2+2. Tho I'm thinking of trying the tri-power on the 400 already in it.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
The Following User Says Thank You to GT182 For This Useful Post:
  #1902
Old 05-05-2026, 08:10 PM
carcrazy carcrazy is offline
Sent out my 62 GP (425A, 4 speed car) for a heart transplant. Found an original 11B engine and finished building it a year and a half ago. Somewhere around 500 hp. Haven't had time to do it myself....... so off to the shop. They are only doing the swap and hooking everything back up. Hopefully get it back within a few weeks, then I'll install the carbs Mike Wasson built and the distributor that was done by Sun Tuned. The tri power engine that is being removed will be for sale in the classifieds in the near future.
The Following 2 Users Say Thank You to carcrazy For This Useful Post:
  #1903
Old 05-06-2026, 08:36 AM
form74's Avatar
form74 form74 is offline
Yesterday Changed the oil on the 75
Than finished getting the new motor for the 74 ready for the dyno
ID:	669524   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following 5 Users Say Thank You to form74 For This Useful Post:
  #1904
Old 05-07-2026, 03:55 PM
Radman's Avatar
Radman Radman is offline
Got the new kick panels yesterday. painted them with matching interior paint. Today I clay bared the car. Waiting for warmer weather to shoot the carpet with interior dye. Want to refresh the carpet, and the garage is attached to the house. Want to be able to open the garage doors so that the smell dosen't get inside the house.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
The Following User Says Thank You to Radman For This Useful Post:
  #1905
Old 05-07-2026, 06:45 PM
jhein's Avatar
jhein jhein is offline
Removed the back half of my exhaust system to make way for the new dual muffler setup. M18 reciprocating saw made quick work of that. Reinstalled the alternator which I had to remove to get the fuel pump out.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #1906
Old 05-10-2026, 07:08 AM
Drove down to a neighboring town about a half hour away to see a large Cars-n-Coffee. No dice: "Evento Cancelado". This I found from a driver of a hotted up Renault - schedule is on Instagram/Facebook. Dammit.
The ride back was nice until I spied clouds of a weird purplish-blue color to the West.
Uh-oh.
Traffic was being held up by some jackass doing half the limit (not uncommon here, 1/3 do not have insurance). Then the rain started - misty first, and then the shiat came down, as was the top.
Finally got to a gas station and raised the top. Also the wiper motor decided it was Sunday and stopped working. Got home, dried off the interior and will now sort out the wiper issue.
  #1907
Old 05-10-2026, 11:16 AM
tempest1964's Avatar
Finished the install of my ‘64 wood wheel. The one that only came with the rim/4 spokes. Had to fabricate the stainless hub. And fit the horn plunger that contacts the brass horn ring and the spring washer. Horns blows!
ID:	669817   Click image for larger version
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following 3 Users Say Thank You to tempest1964 For This Useful Post:
  #1908
Old 05-10-2026, 01:19 PM
Did the running lights/headlight mod for my car. Now running lights are on with headlights.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
The Following User Says Thank You to tempest1964 For This Useful Post:
  #1909
Old 05-11-2026, 12:25 PM
Verdoro 68's Avatar
Stopped by the body shop on Friday to see how things are coming along. He repainted the front bumper to fix the damage from the cars and coffee incident. I also had them improve the front end sheetmetal alignment and fix a few chips and dings which included repainting the driver's side 1/4. He ended up reclearing about 1/2 the car. Overall it looks good. They kept the car pretty clean and matched the paint well. Just a few little things to fix before I take it home.
ID:	669899   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 10 Users Say Thank You to Verdoro 68 For This Useful Post:
  #1910
Old 05-11-2026, 02:05 PM
VCho455's Avatar
VCho455 VCho455 is offline
I'm disappointed to hear you had to do this. I was planning to run a transverse muffler with my Tanks Inc fuel tank. On the other hand it appears that you have saved me the effort of trying to put that puzzle together.
I don't remember ever seeing which version of their tank you have. Do you have the notched version?
  #1911
Old 05-11-2026, 03:04 PM
jhein's Avatar
Well, I wouldn't say that I "had" to do it. I'm certain it could be done with the transverse setup but it was just making the job more difficult. Plus, even with the access door, it will make maintenance easier. And I still need to pull the axles to do the rear brake upgrade so that will be easier.
Now, about the tank, I have the 20.5 gal non-notched tank. Even though it was really close to the transverse muffler, it did clear the tail pipes easily. I'm pretty sure I'll be OK with the new tail pipes but there is a chance they may not clear. Neither Pypes or Tanks inc could tell me for sure. I found some pictures and videos that I think have the Tanks 20.5 gal tank and the Pypes dual muffler exhaust so I've got my fingers crossed. We'll see.
  #1912
Old 05-12-2026, 08:17 AM
form74's Avatar
Dyno day yesterday same motor prepped correctly made 30 Horsepower more
Now get in back in the car and see the results at the track
ID:	669942   Click image for larger version
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
The Following 7 Users Say Thank You to form74 For This Useful Post:
  #1913
Old 05-12-2026, 12:16 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Very nice power bandwidth between peak torque and peak power! A/F ratio is close to perfect across the board.
The Following User Says Thank You to srmmmm For This Useful Post:
  #1914
Old 05-12-2026, 02:05 PM
form74's Avatar
Here is Dyno sheet from the first build of this motor. As you can see their is a huge difference
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
The Following User Says Thank You to form74 For This Useful Post:
  #1915
Old 05-12-2026, 02:42 PM
johnta1 johnta1 is online now
So this is a 461 now and not 469 cid?
Also the times in your sig are for the 469 (old engine)?
Should be a nice improvement if so!
  #1916
Old 05-12-2026, 03:23 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice job ..... Folks can see the worth of a professional builder vs assembler, in this case a professional assembler.
Troy's Dyno has always been spot on. I'm glad you'll finally see the benefits from the money you spent for performance.
Go fast, see Elvis!
  #1917
Old 05-12-2026, 03:26 PM
PAUL K's Avatar
469 was an iron headed engine that lost a factory cast rod after many years of racing.
461 is a stroked 400 with aluminum heads.... Both posted Dyno sheets are from that same engine. The second builder basically blueprinted the engine and made everything correct
Go fast, see Elvis!
  #1918
Old 05-12-2026, 08:10 PM
form74's Avatar
Yes was a 60 over 455 , threw a few rods Now a 400 Stroker
Yes times were from old iron headed motor that Paul K built
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
The Following 2 Users Say Thank You to form74 For This Useful Post:
  #1919
Old 05-12-2026, 09:56 PM
I think you will be real happy with it.
  #1920
Old 05-13-2026, 01:23 AM
Verdoro 68's Avatar
Got the Goat back. As my wife was dropping me off at the shop she said "I feel bad for them because they have do deal with your nitpickiness."
I'm honestly impressed with how clean they kept it. The original shop that painted it were slobs by comparison. There's a little haze over the engine compartment, but nothing a good wipe down won't fix. I know you're supposed to wait with new paint, but I hated seeing it without the decals on the 1/4 so I put a fresh set on this evening. Yes, that's a level in the reflection.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
