Old 05-31-2026, 03:39 PM
02CiC 02CiC is offline
Default PS pulley problem
Hi all. Removed the PS pump for a swap, as the belt was heating super noisy. Belt replacement didn't help (although the old belt was beat up). Used a pulley pull tool to remove the old pulley. Bought a replacement pump from Classic Industries but neither the original NOR the replacement pump has threads in the center of the shaft for the pulley installation tool to attach to. The old and the replacement pumps and pulleys have slots for the woodruff key and they are aligned, but I can't get the darned pulley on either pump. Help!
Old 05-31-2026, 07:27 PM
SRGN SRGN is online now
The internally threaded shaft is only for press fit pulleys IIRC. Sounds like you have a press fit pulley and pumps designed for a retaining nut/keyway style. Post pics if you can.
Old 05-31-2026, 08:33 PM
Thank you! The guy at the garage down the street managed to shimmy it on, worked like a charm! Now the issue is the power steering still squeaks like crazy. Replacing the pump and belts had no effect. I can see when it's squeaking that the pulley stops turning abruptly with each squeak. The Internet says that I may need a new pulley, but why would my pulley have become misaligned or out of round, or dysfunctional before doing anything to the belts or pump? In other words, why did this thing start squeaking after 20 years of ownership and flawless, mechanical function.?
Old 05-31-2026, 09:59 PM
I'll try to get some pics tomorrow, I have a couple of Pontiac PS pumps for reference. What fluid are you running? It's possible that the valves or ball assembly in the steering box are stuck/damaged and causing a fluid blockage.
Old 06-01-2026, 03:25 AM
I was afraid of that. Dexron III
ID:	671194   Click image for larger version
ID:	671195   Click image for larger version
Old 06-01-2026, 10:44 AM
73ta's Avatar
73ta 73ta is online now
You need a wider PS belt so it rides at the same height as the other belt in the pulley. They are trying to go different speeds. Pontiac specked a wider belt for PS on some late 60's engines. I just went thru this on my 455.
Old 06-01-2026, 11:55 PM
That would be amazingly simple. Here's what I bought from Autozone. Where and how would I get a wider belt?
The one I bought in the attached pic is 0.44" wide. Autozone has one the same length in their 17 series that's 0.53" wide. Classic Performance only sells one that is 0.469". Wondering which to get.
Old 06-02-2026, 06:48 AM
Originally the belt widths were 3/8" (.375") for alternator and 1/2" (.500") for the PS. (I think anyway)
Now they are probably made metric.
Try and get close to the widths for each one might help?
Old 06-02-2026, 11:30 AM
73ta's Avatar
Get the 0.53" wide belt.
Here's what I'm using on my 73 455:
Vbelts
Alternator: Gates 7490 – 49.0”
Power Steer: Gates 9530 – ½” X 53.375”
AC: Gates 7585 - 58.5”
Old 06-03-2026, 10:05 AM
Vbelts
I tried the wider belt but can't get it to go on all of the pulleys. It sits too high. Can I just get a bigger diameter than 51.5"? Only need about another inch or so. Maybe 52.5 or 53"?
Old 06-03-2026, 12:01 PM
Forgot to mention that when I replaced the two drive belts, both were the same with, one is part 15500 and the other is 15515. Both are the same brand and the only difference is the alternator belt is 50 inches, and the power steering belt is 51.5 inches in diameter. Do you still think that I should just put a wider belt on the power steering to see if it will stop squeaking and seizing?
Old 06-03-2026, 12:36 PM
73ta's Avatar
Yes, fixed my problems. Factory manual for 1973 shows same width belts, but earlier pre 70 some models used a wider PS belt. My pulleys came from an unknown source. My belts ride at the same height in the double pulley grooves now in my WP and crank pullies. Fixed my belt noise.
Check gates site for belt specs. My PS belt is Gates 9530 – ½” X 53.375” long.
"one is part 15500 and the other is 15515" those are the same series belts, 15 series, and the same width? Pulleys have two different groove widths is my thought.
Old 06-03-2026, 01:30 PM
Given that it was good for a long time and the issue suddenly came up, I'm inclined to believe it's more than just a belt issue. I'd start with pulling the lines off the box, draining the fluid, and turning the wheels back and forth slowly from lock to lock(wheels off the ground) to get the old fluid out. I would try regular power steering fluid to refill after reinstalling the lines. PS fluid is a little easier to push than ATF given the difference in viscocity. I'm assuming that the issue is occurring at idle, make sure your idle speed is set to spec as well.
Old 06-04-2026, 02:58 AM
Thank you for this, it is at idle and also when doing sharp turns at very low speed. In any case, I bought an AX50 Gates belt 1/2" x 52", and it worked like a charm!
I'm so grateful for all the help here, only now wondering if I should have even replaced the pump or tried your belt tricks first. In any case, it feels great to have a sorted car again!
You guys rock!
The Following User Says Thank You to 02CiC For This Useful Post:
