Old 06-07-2026, 07:56 PM
hgiv hgiv is offline
Default Prebent tranny cooler lines! Ugh
I bought a set of prevent tranny cooler lines from Summit for my 69 bird. It’s like some sort of ungodly puzzle. The line that goes into the upper fitting on radiator is I’m possible. I spent an hour on it. Walked away and came back next day without progress. Either line is wrong or I’m missing something!! I’m DONE. I ordered all the fittings and lines for 6AN lines. At this point I’m not looking for help just sharing my misery.
Anybody need a set of steel prebent tranny cooler lines? You pay the shipping and their yours!!
Old 06-07-2026, 10:37 PM
SRGN SRGN is offline
Only prebent stuff I've ever had good luck with was from inline tube. Everything else was close, but not quite. Some were worse than others.
Old 06-08-2026, 08:30 AM
grivera's Avatar
grivera grivera is offline
I’ve used Inline Tube on my bird with zero issues.
Will Rivera
Old 06-08-2026, 10:53 AM
bdk1976 bdk1976 is online now
My most recent experience with inline tube (earlier this year for a semi-OT '71 GMC) the rear axle lines they sent were either bend wrong and/or incorrect for the application (this was after them shorting me parts on the original order). I've had decent experiences ordering from them in the past but this was not one of them.
Old 06-08-2026, 05:40 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
I bought a set of tranny lines this year from Inline Tube and they were perfect, I set them next to my original ones and perfect match for my 68 GTO.
color me gone
The Following User Says Thank You to 1969GTO For This Useful Post:
Old 06-14-2026, 07:12 AM
BLK/RD462TA's Avatar
BLK/RD462TA BLK/RD462TA is offline
Send a message via AIM to BLK/RD462TA
Default Trans lines
I have a 78, I had installed prebent lines several years ago. I had to replace engine. It took me some time to snake them back in. I was frustrated because I houdini them in years ago. I had to separate them to have a chance. Just venting, sometimes the simple things are annoying 😑
78 T/A 3,750lbs 1 5/8 headers
462 #16 D-ports 250ish CFM
Lunati solid flat #40707
T-350 9" ATI, 3.90 gear
27" QTP on 8" weld stars
Holley 750 vac- RPM
ET- 11.3 @ 119.55
pump gas 9.5-1 comp
Old 06-14-2026, 07:28 AM
tjdjr's Avatar
tjdjr tjdjr is offline
I bought mine from Ames years ago and they fit well, it was a bit of a challenge snaking them into place. I ran them in from the front between the engine and manifolds, it only took a few new curse words.
Old 06-14-2026, 09:50 AM
mgarblik mgarblik is offline
I installed cooler lines from Inline tube in a second gen Firebird recently. The were well made with nice, crisp bends and well formed ends. I put masking tape over the nuts and ends so they wouldn't scratch the paint off the chassis and oil pan. They did require some minor bending and fitting around the oil filter housing and the modulator. Overall, happy with them. I especially liked that they were shipped in a 6' long box. So no bending to fit them in the box.
Old 06-14-2026, 10:06 AM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
I went with these
https://www.summitracing.com/parts/sum-230321
I am the Thread Killer!
Old 06-14-2026, 10:24 AM
I have used the Summit branded braided steel hoses and the Doorman ones for fuel lines on Chevy trucks. If your not concerned about a stock OE look, they are a great option IMO. Since they are not self supporting, make sure you use lots of zip ties or clamps.
Old 06-15-2026, 09:01 AM
I went with all 6AN. Way easier.
The Following User Says Thank You to hgiv For This Useful Post:
Old 06-15-2026, 09:40 PM
1966Lemans's Avatar
1966Lemans 1966Lemans is offline
I used these...
https://www.summitracing.com/parts/sum-230321-b
Since they're black, they don't look out of place in the engine compartment.
'67 Piper Cherokee
'66 Lemans
