Old 06-21-2026, 08:01 PM
67Lemons 67Lemons is offline
Default What air horn can I use for a 7042263 Quadrajet?
One of the accelerator pump ears on my ‘72 Quadrajet is cracked and I want to replace the air horn, since I can’t find the exact carb as a core, what other numbers can I use?
1972 GTO
Old 06-22-2026, 04:05 AM
Kenth's Avatar
Kenth Kenth is offline
You may consider this:
https://www.carburetion.com/Products...px?part=R24-55
or:
https://quadrajetpower.com/accelerat...ng-repair-pin/
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-22-2026, 07:09 AM
I have one and installed it but not confident in it as a long term solution, I’d much rather a replacement air horn.
1972 GTO
Old 06-22-2026, 07:46 AM
carbking's Avatar
carbking carbking is offline
The airhorn used on the 7042263 carburetor is unique to that application.
If it were mine, I would simply repair the original. It really is not difficult, I have posted the method on this forum in the past.
Jon
The Following 4 Users Say Thank You to carbking For This Useful Post:
Old 06-26-2026, 02:31 PM
chiphead's Avatar
chiphead chiphead is offline
I've got a desirable core that has this ear broken. Its been in a box of carbs for years, I figured it was wasted. Thanks for this!
Old 06-27-2026, 06:57 AM
Repair is realistic. Did that and it held for, well probably still holding.
