Old 06-24-2026, 09:22 PM
Zach Zach is offline
Default 77 Trans Am Cluster Help or Diagram
Howdy, replacing the circuit board in my cluster, also replacing some bulbs. I am curious what the bulb circled in red is for and what purpose the metal is supposed to have. There was nothing attached to it when I pulled the cluster. There is evidence that someone else has been in this dash before though. Thanks.
1977 Trans Am with a tach
Old 06-25-2026, 09:49 AM
78w72 78w72 is offline
Looks like the fiber optic fitting for the ash tray light, there should be a long fiber optic wire coming out of the metal housing that goes to the ash tray.
Old 06-25-2026, 01:54 PM
steve25 steve25 is online now
Yup, for the Fiberoptic .
Old 06-25-2026, 11:20 PM
Appreciate the clarification. Car doesn't seem to still have that wire, my harness is a mess from the previous owners. Just making sure it wasn't anything too important.
Old 06-26-2026, 06:59 AM
The fiber optic cable isn't a 'wire' so probably not included in a wiring harness.
The fiber optic cable goes to the back of the lighter which is probably still there unless lighter is removed?
Old 06-26-2026, 07:14 AM
A fiber optic cable looks like monofilament fishing line that’s black most times.
Old 06-26-2026, 05:15 PM
P@blo's Avatar
P@blo P@blo is offline
My 1981 has two of those but appear to be attached to regular wires. One one the standard 8 illumination bulb, black drk. blue, and the other to the 33 brake light bulb , black lgt blue, that looks to be a ground. The warning can be activated by the emergency brake on or pressure issues with the combination valve.
Not sure why the manual has the gauge circuit upside down.
Old 06-27-2026, 05:55 PM
VCho455's Avatar
VCho455 VCho455 is offline
That's so when you've got your head crammed under the dash it looks right side up. 😀
