Old 06-30-2026, 12:51 AM
ricks63 ricks63 is offline
Default 72 TRANS AM HEI DISTRIBUTOR
Can someone tell me if a h.e.i. distributor from 72 Trans Am is worth anything? I believe it came as a option on the car, it is complete with wires. Thanks any info would be appreciated.
Old 06-30-2026, 11:43 AM
65madgoat's Avatar
No HEI in 1972....
Old 06-30-2026, 01:26 PM
johnta1 johnta1 is online now
They had an unitized distributor in 1972, it kind of looks like a HEI.
Need the distributor # off of it to make sure what it is.
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
Old 06-30-2026, 09:40 PM
This is a pic of one from an ebay ad:
Old 06-30-2026, 11:20 PM
Formulabruce's Avatar
This unit was only on the 455HO IIRC which made that car "Good reliable transportation" in a 1972 Formula455HO advert.
" Long may we DRIVE !"
Old 07-01-2026, 12:04 AM
Region Warrior's Avatar
Think 1st yr was 74 in 455s
Standard all v8 in 75.
Old 07-01-2026, 08:16 AM
tcom tcom is offline
Does anyone run the 72 unitized dist ? or tried to modernized its components?
Old 07-04-2026, 08:36 PM
Yes i meant unitized, the numbers on it are 1112133 1H 4
It came off a 72 Trans Am , i believe it was ordered with it. Same as the ebay pic someone posted . Thanks any help appreciated.
Old 07-04-2026, 09:30 PM
Those are probably worth quite a bit of money?
Old 07-05-2026, 04:44 PM
FrankieT/A's Avatar
I run the Unitized with no problems. I replaced the wires in 1985. Found an AC Delco set on the shelf of an auto parts store back then, bought them and they've been on there ever since.
Old 07-05-2026, 04:45 PM
FrankieT/A's Avatar
Yep that's it.
Old Yesterday, 07:55 PM
Default PM PROBLEMS
To the people that sent me pm's regarding the distributor, sorry but i'm having problems with my messages and lost them before i could reply. Please try sending again. Thanks , Gregg i tried sending you a text about the rear end and distributor to the number i had contacted you a while back but have not heard back. Maybe you have another number. Please send a message if thats the case. Thanks
