Can someone tell me if a h.e.i. distributor from 72 Trans Am is worth anything? I believe it came as a option on the car, it is complete with wires. Thanks any info would be appreciated.
No HEI in 1972....
They had an unitized distributor in 1972, it kind of looks like a HEI.
Need the distributor # off of it to make sure what it is.
| The Following 2 Users Say Thank You to johnta1 For This Useful Post: | ||
This is a pic of one from an ebay ad:
This unit was only on the 455HO IIRC which made that car "Good reliable transportation" in a 1972 Formula455HO advert.
" Long may we DRIVE !" |
Think 1st yr was 74 in 455s
Standard all v8 in 75.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
Does anyone run the 72 unitized dist ? or tried to modernized its components?
It came off a 72 Trans Am , i believe it was ordered with it. Same as the ebay pic someone posted . Thanks any help appreciated. |
Those are probably worth quite a bit of money?
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
I run the Unitized with no problems. I replaced the wires in 1985. Found an AC Delco set on the shelf of an auto parts store back then, bought them and they've been on there ever since.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
To the people that sent me pm's regarding the distributor, sorry but i'm having problems with my messages and lost them before i could reply. Please try sending again. Thanks , Gregg i tried sending you a text about the rear end and distributor to the number i had contacted you a while back but have not heard back. Maybe you have another number. Please send a message if thats the case. Thanks
