Old 07-04-2026, 02:50 PM
Terry M. Hunt Terry M. Hunt is offline
Default Engine lifting loop
Should this piece be placed against the timing cover and retained by flat washer and nut? Or should it be placed against the nut retaining the timing cover as shown in the attached photo and retained by a second flat washer and nut?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 07-04-2026, 04:22 PM
I believe it should go against the timing cover and be retained by a single nut.
Old 07-04-2026, 05:21 PM
OG68 OG68 is offline
Against the timing cover with no washer.
Think of the tab as a big washer.
The Following 2 Users Say Thank You to OG68 For This Useful Post:
Old 07-04-2026, 05:47 PM
Okay, thanks guys
Terry Hunt
Old 07-04-2026, 06:49 PM
gto4ben gto4ben is offline
According to the 1967 assembly manual, there is a 548375 spacer between the cover and the hook.
ID:	672839   Click image for larger version
The Following User Says Thank You to gto4ben For This Useful Post:
Old 07-04-2026, 07:54 PM
Forgot to mention in initial post that I’m working on a 66 GTO, so maybe no spacer like that illustrated for 67.
Terry Hunt
