Old 07-05-2026, 11:44 AM
GoGoat GoGoat is offline
Default 67 & 68 Firebird rears
Are they the same?
66 GTO Conv Tripower 4 spd stock
67 GTO HDTP 400 auto stock
70 Judge 400 RAIII 4 sd stock original
69 Firebird 468 auto 28 option
49 F1 302 aod
Old 07-05-2026, 12:05 PM
I'm referring to the rearend housings. Sorry. Thanks
49 F1 302 aod
Old 07-05-2026, 12:14 PM
Yes that are as far as bolting in the rear track width is 60”, but in both years and even up thru 1969 there carrier’s
will only accept certain gear ratios as in.
2.56 to 2.78.
2.93 to 3.23.
3.36 to 4.33.
In 68 all the manual transmission cars got the HD 4 pinion Posi with 3.36 to 4.33 gears ( if the car did not have AC )and even the 6 cylinder cars with a manual trans supposedly got the HD 4 pinion rear also .
Naturally auto trans cars could have had the HD on special order.
In mid 69 the ring gear bolts changed from 3/8” to 7/16”.
Old 07-05-2026, 12:44 PM
Cammer-6 Cammer-6 is offline
Actually 69 is closer to 68 than 67 is.
68-9 used multi leaf springs,staggered shocks
67 used mono leaf
67 also used radius rods(like traction bars)
69 had flat spots on tubes for jounce bushings
internals were same as the GTO/LeMans/Tempest
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old Yesterday, 11:25 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Originally Posted by GoGoat View Post
Are they the same?
As mentioned, they are mechanically interchangeable, but they are different parts. the center section of the '67 is from an A-body and it has the upper 4 link mounts cast into it but are not used on the leaf spring F-body cars.
As mentioned- the '67 housing could be had with traction bars if you had a 326HO or 400 model. they were separate mounts on the housing and had mounting plates welded into the floor pan of the Firebird. I believe autos had one bar and the manuals had 2. both my '67 326HO 3 speed manual) and '67 400 (4 speed manual) have 2. Attached is a pic of my '67 400 4 speed rear axle for reference. so there are a few different housing set ups depending on your 1967 Firebird model.
Bottom line is if you're looking to get your car driving either would work. if you're restoring a car to be correct you need the right year and version (if 1967)
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
