Dorman bushing is magnetic. looking through old thread Ken (Pontiac Dude) said even old ones were and no issues if a dab of grease.
McLeod has a 1380-1 Pontiac (as well as -7 extended) that are listed as oilite.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Back from my friends cabin. Measured the National I had vs. the NDH that was removed and they were close to each other using my 0.001 dial caliper. But, I didn't use the National for some reason (see later) other than the width was 0.352" vs. 0.354" (NDH). Real reason was 8 bearings vs. 9 on original.
So long, farewell. |
Got a spec?
So got the McLoed today Comparison to Dorman
Dorman -actual stamped 0174523 OD 1.3795 ID 0.595 thickness 0.436 mcLeod OD 1.3819 ID 0.5935 thickness 0.351 BOTH are magnetic. In their catalog it does not list the Pontiac as oilite whereas the SBF same OD is-different ID, and some GMs. They do make a thicker one for Pontiacs.
OE (NDH) was... 9 bearings OD 1.3770" (34.97mm) ID 0.5900" (14.99mm) Width 0.3530" (8.97mm) National was... 8 bearings OD 1.3765" (34.96mm) ID 0.5900" (14.99mm) Width 0.3520" (8.94mm) L&S was... 8 bearings OD 1.3765" (34.96mm) ID 0.5900" (14.99mm) Width 0.3510" (8.93mm) What I did use was ordered under PN 15533265. 9 bearings Nothing else was checked at the time.
Dorman was snug but could push in with fingers so went with the McLoed it had to be tapped in with a little force
