I guess I have a couple questions.
My ‘55 Catalina has that Carolina squat going on. The front sits higher than the back. I like the height of the back, so want to lower the front. So I guess I need to find out what the measurements are for stock front and back ride height. I know I found this info years ago for my GTO in one of my manuals, but can’t find it for my 55. So next question is, if the measurement for the front comes out close to stock, does anyone make a lowering spring? I see SO many posts these days with guys complaining about aftermarket springs not actually sitting at the height they are advertised to sit at. Thanks
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
I think these pictures will show it a little better. Would like front about 2” lower.
If you can find an old spring catalog, they would list all the specs for their springs. Figure out the part number for the stock ones, the old catalogs would list everything from diameter to spring rate, ends and length. Find a spring with the same specs, 2" shorter. I have no idea where my old trw catalog is that I used, after I sold my father's house a couple years ago I haven't found half my stuff yet. I could really use it so I could figure out a spring for my Catalina, back is where I want it but the front needs to come up an inch.
| The Following User Says Thank You to SRGN For This Useful Post: | ||
Try contacting Eaton Detroit Spring. They have specs for the original springs and can make custom springs based on the original spring rates.
I had a ‘57 Bel Air many years ago that I lowered using 2nd-gen F-body front springs.
You could likely do it on the cheap with a pair of good used springs, as long as they’re the same diameter they’ll work. It’s either that or roll the dice on expensive aftermarket springs. Also lowered the front of my ‘64 GTO with a new pair ($60 at the time) of ‘67 Firebird springs. So there’s a lot of interchangeability with GM front springs.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
Cut 1 coil.
Easiest way to do it is to undo the inner mount bolts & lower the A frame, no need to get involved with the King pin
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
| The Following User Says Thank You to 694.1 For This Useful Post: | ||
