Old 02-03-2012, 09:47 PM
Held for Ransom's Avatar
Why can I only remember certain things about threads nowadays.
I went to look at a 34K mile '79 today and took photos (L car, 03B). Hope they help someone.
ID:	273216   Click image for larger version
ID:	273217   Click image for larger version
ID:	273218   Click image for larger version
ID:	273219   Click image for larger version
  #42
Old 02-04-2012, 12:53 AM
2manyT/A'S's Avatar
So this would be the recall 15" spare for the WS6 cars?
Eye Candy......garage band?
Go full screen & turn it UP!
  #43
Old 02-04-2012, 10:24 AM
I asked him about it. He stated it was never touched or replaced. Small town. I assume that by Mar. '79 they were putting the correct spare in place, as the campaign was put in place in Dec. '78.
  #44
Old 02-04-2012, 11:03 AM
Father&Son73T/A Father&Son73T/A is offline
Regardless you could never run a space saver on the rear cause of the posi correct?,without damage?
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #45
Old 02-04-2012, 11:50 AM
GT182's Avatar
GT182 GT182 is offline
I was told you could run the space saver for any wheel that went flat. Never had a flat so I never got to try it.
Tread code has faded but it looks like what's been posted already by 165th and others for 79 WS6
Code on tire sidewall... HPVV CUO, DOT Code - 069
Valve Stem.... 6B 2 [then valve stem] 15 RF
Serial number on my 79 Formula was ... 9N159677 Ordered in Nov of 78, but not delivered until May of 79. Build sheet is long gone, but looks to be past the recall date for the spare.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #46
Old 07-07-2026, 09:09 PM
thepontiacman's Avatar
Default Pics space saver
I just got a space saver spare with L9CU on the tread. BF Goodrich, from the info above ,looks like it is original for a 78 Norwood car. Black rim with yellow decal, stamped EL. near valve stem. HS in the middle near lug holes.
Let me know if this is correct.
ID:	672971   Click image for larger version
ID:	672972   Click image for larger version
ID:	672973   Click image for larger version
ID:	672974   Click image for larger version
  #47
Old 07-07-2026, 11:11 PM
I'm thinking earlier. 1978 was stamped UA, I believe. EL may be 1975 or '76 going by the tag. Need to see better stamping pictures around the special valve stem.
So long, farewell.
  #48
Old 07-08-2026, 12:28 PM
Default Space saver spare
Pics
ID:	673020   Click image for larger version
ID:	673021   Click image for larger version
ID:	673022   Click image for larger version
ID:	673023   Click image for larger version
  #49
Old 07-08-2026, 08:05 PM
Better yet, what is the DOT number?
So long, farewell.
  #50
Old 07-09-2026, 06:56 PM
Default Pics
Dot numbers
ID:	673076   Click image for larger version
  #51
Old 07-09-2026, 08:22 PM
Dot numbers
025. 2nd week of 1975.
So long, farewell.
  #52
Old 07-09-2026, 08:38 PM
Thanks for the info.
It has been in a 70 for at least since 79. Not sure how it got there.
