Old 07-08-2026, 12:08 PM
Default Slotted chome valve cover braces-brand?
I have some older chrome valve cover braces they were slotted 5/16 so they could sit flush. The Summit and Moroso I just got are not and do not fit the recess on the chrome repop valve covers. The hole needs to be slotted to move them out vs just grinding on the outside radius. Anyone have a brand?
Old 07-10-2026, 02:16 AM
Schurkey Schurkey is offline
Are you talking about the Corvair-style load spreaders? Chevy small-block guys used them, and when they got popular, companies started stamping them to fit BBC and other engine families.
Sort-of like these:
Old 07-10-2026, 05:39 AM
SRGN SRGN is offline
I picked up a set from a guy on eBay that fabricates them. Not cheap, but I'd rather pay more for something made here by American hands. Im not disappointed.
https://ebay.io/m/IahyTk
Old 07-10-2026, 09:02 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Why are the ends on some drilled and taped? what am I missing
Old 07-10-2026, 12:12 PM
Says they're drilled and tapped for adding plug wire looms. I thought about using them for that purpose, but I have too many other things to work on before I get to it.
Old 07-10-2026, 12:21 PM
Yes those type but as you look at the picture it is a round hole. On the Pontiac valve covers the radius around the bolt recess in the valve cover will not allow it to actually be on the flat surface of the valve cover unless it is slotted. Even grinding the outer portion the radius doe not fit. Not sure what brand I got that is slotted so the whole thing slides out some
Name:	Valve cover brace 1.jpg
Old 07-10-2026, 01:03 PM
I guess your talking about using such on original Pontiac valve covers because I have used the type as in the photo on Moroso steel covers and cast aluminum covers.
If I recall right both the spreaders and the cast aluminum covers were made by Cal Custom, although I am sure Mr Gasket offered the spreaders also.
I don’t know if that company is still around, but once again if I recall right the cast covers I got thru good old J.C Whitney.
Old 07-10-2026, 01:53 PM
george kujanski's Avatar
I use those on the chrome valve covers I have, they look original and the spreaders fit fine.
George
Old 07-10-2026, 02:48 PM
Have several skinpacked cards of Moroso BBC chrome spreaders from the late 70's/Green Light Auto cleanout.
Believe the radius is bigger on them than the stamping on Pontiac stamped covers.
Old 07-10-2026, 03:44 PM
sdbob sdbob is offline
Back in the early 70s I bought GM corvair clamps drilled to fit stock steel covers
Old 07-10-2026, 05:32 PM
I can use a small 5/16 end mill in my drill press and make a slot but be easier to find the ones I used on the 455 I just dynoed.
Old 07-10-2026, 05:46 PM
Mike Davis's Avatar
Trans dapt makes them as does Moroso.
Trans dapt part number 9641
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 07-10-2026, 06:38 PM
I think those are the ones I have. I'll shoot a picture of the slotted one.
Old 07-11-2026, 12:15 PM
Comparison pics
