Old 07-20-2026, 01:02 PM
Joe Joe is offline
Default end carb venturi clusters
on the left is an OEM piece. One on the right I pulled the idle tubes out to use on an end carb. Do I need to fill the holes with some sort of epoxy or use as is. thanks Joe
Name:	end venturi cluster.jpg
Old 07-20-2026, 02:06 PM
Kenth's Avatar
Kenth Kenth is offline
Since there are no idle channels in end carb bowls and plates you can leave the idle tube holes as is.
However youŽll need to plug the upper idle air bleeds and open the main well air bleeds and accelerator jets to end carb specs.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old Yesterday, 08:52 AM
Joe Joe is offline
Thanks once again for your help. for clarification... when you state upper idle air bleeds are those called " primary idle air bleeds " ? If II have to plug them I should be able to syringe some liquid epoxy down the hole where I pulled the idle tubes out correct?
also, what do you mean by accelerator jets?
Much appreciated.
thanks again,
Joe
