Old 07-21-2026, 01:37 PM
rascal455ho rascal455ho is offline
Default Tin Indian performance 041 hydraulic roller
Anyone have a videoclip of idle with this cam ?
The Following User Says Thank You to rascal455ho For This Useful Post:
Old 07-21-2026, 02:39 PM
Are you considering putting this in your 455 HO, if so is your HO the high comp 1970 version?
Old 07-21-2026, 10:10 PM
No it’s a 9.5 to 1
Old 07-22-2026, 07:18 AM
I went to Tin Indian site and they do not list the info for that grind unfortunately.
If we assume that it’s close to the original Cam then a 455 should idle 11% better then that Cam would in a 400 due to the 11% greater stroke of the 455.
I think there can be found a video of how a factory RA4 Cam idles in a stock RA4 motor, so you could at least listen to that.
Are you planing on running the 1.65 ratio rockers that would normally go with that Cam?
I guess you could also contact Tin Indian and get there opinion once they get back from Norwalk.
If nothing else your 12% bigger then a 400 motor should pull more idle vacuum.
I don’t know what your looking for in terms of a power band for your motor, but you can consider the hp numbers to be nosing over pretty well with a 455 motor by the time 5600 rpm comes around.
I would say that torque production would peak by 3800, so you should use that for setting up your converter if auto and rear gearing for your proformance needs.
Here a recommendation chart that HO racing use to publish on the subject.
To this day this chart is still very accurate in regards to a street / sometimes strip motor.
If your not planning on doing a lot of long distance highway driving, then do not disregard what the chart recommends for rear gearing if your running tall rear tires!
Old 07-22-2026, 09:43 AM
Stan Weiss's Avatar
Remember that roller cams don't have the same limitations that flat tappets do and so some may have more lift with 1.5:1 rocker arms
Part # CCA-BP-RA-041-HR-CL
The Butler RA Series is an updated cam lobe designed and ground by COMP CAMS exclusively for Butler
Lift with 1.5 ratio rockers: .507/.541
Lift with 1.65 ratio rockers: .557/.595
Duration: 232/241
Lobe Separation Angle: 113
Hyd. Roller
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 07-22-2026, 10:00 AM
napster1 napster1 is offline
This is what the butler roller version of the 041 sounds like in a 406.
https://www.youtube.com/watch?v=bgWqk_7qjcA
The Following 3 Users Say Thank You to napster1 For This Useful Post:
Old 07-22-2026, 11:09 AM
In a 455 it will sound more tame.
Old 07-22-2026, 11:32 AM
RAIIIJudge's Avatar
RAIIIJudge RAIIIJudge is offline
Lunati 041 in a 400 w/ 1.65s
https://www.dropbox.com/scl/fi/vibun...=vcnaefg0&dl=0
Mike
'69 Midnight Green Judge 462 Ported 48s RAIII Exh Manifolds 4spd 3:73s
The Following User Says Thank You to RAIIIJudge For This Useful Post:
Old 07-22-2026, 12:08 PM
Here are the details of the build using Butler Performance Ram Air Series cam - Roller 041
W72 988 block, .030 overbore for a 406 cubic inches, Stock crank, Eagle Forged H-Beam connecting rods, Forged TRW pistons, Holley Brawler 750 Double Pumper, Port matched Edelbrock Performer RPM intake manifold, Edelbrock performer RPM 72cc Heads (Ported), 10:1 compression, Butler's Roller 041 Cam, 1.65 scorpion roller rockers, Comp Cam roller Evolution lifters, round port Doug's headers 1 7/8th primary and 3.5 inch collectors. Exhaust is 2.5 inch mandrel bent pipes with an H-pipe thru Texas T/A mufflers. Estimated numbers are 450HP and 480TQ. Time constraints did not allow any dyno action.
The Following User Says Thank You to napster1 For This Useful Post:
Old 07-22-2026, 12:09 PM
From site
Old 07-22-2026, 12:17 PM
Specs are very close to the Butler version.
Old 07-22-2026, 12:25 PM
Napster I must say that your HP estimate of 450 hp is low for your combo, I would say 480 should be much more like it.
Old 07-22-2026, 01:35 PM
Was told Ross piston out of cylinder a hair . 6x8 240cfm Torker II 850 Quickfuel race
Old 07-22-2026, 01:40 PM
Runs great but would like to tame it down a notch . Rich idle . I’ve done carb adjustments. Transition slots and all . Idle air bleeds .
Old 07-22-2026, 02:03 PM
Other then trying out more timing if you have not already i would say that you have a few choses to try.
In no particular order .
Step down to a 750 carb .
Get annular boosters put in your 850 .
Advance the cam.
Loosen up your lash by .005”.
Switch over to a rpm performer since this will also make your carb seem smaller and this manifold will have no problem restricting your 240 cfm heads .
Note that a rich idle condition will load up the plugs and once that starts the idle rpm will drop off.
Many times folks thing that there motor at idle is smelling rich when in reality that eye burning smell if from being lean .
Please post up a picture of a few of your plugs.
Old 07-22-2026, 02:50 PM
chiphead's Avatar
chiphead chiphead is offline
Go down on the IFRs about 10% at a time until it cleans up.
Old 07-22-2026, 03:24 PM
srmmmm's Avatar
srmmmm srmmmm is offline
Interesting comparison to my build:
1970 350 block bored .060 over, Eagle 4.25" crank, Eagle 6.8" H-Beam rods, Ross flattop pistons set at zero deck height, and 6X-4 heads for 413cu in and a 9.34 CR. Comp Cams XE276HR with 1.5 roller rockers, RA-IV reproduction intake and 800cfm Q-Jet. MSD billet distributer. Hedman long tube headers, Pypes 2.5" X-pipe system with transverse muffler. Dynoed 442 LbFt@4300 and 453HP@5600
Old 07-22-2026, 06:35 PM
I do have an rpm intake and a proform 750 race carb laying around
Old 07-22-2026, 09:55 PM
i82much's Avatar
i82much i82much is offline
how far off is this from stump puller? if it is close, some threads about that cam might be worth reading.
Old 07-23-2026, 09:14 AM
SD Performance revised Stump Puller:
Part number 51-000-11
Grind number: P8 3194B / 3196B HR112+5
281 / 287
230 / 236
.3890 / .3910
112.0 LSA / 107 ICL
His old Stump Puller used lobes 311B and 3122B / note it has less valve lift
If unavailable at SD Performance either of these can be ordered custom with any Comp Cams dealer if desired.
Old information here:
