I used the 3 piece in my 64 mainly because the perimeter metal of mine was good as were the drops.
‘Ospho is a phosphoric acid-based metal treatment that chemically converts iron oxide (rust) into iron phosphate, an inert, hard substance. It acts as a rust inhibitor and surface prep, creating a tough, paintable surface that helps subsequent oil-based paints and primers adhere securely to the metal.‘
I actually used Eastwood chassis black for my frame and was pretty happy with the results. Yours would be fairly easy since you already have the frame separated.
1964 Tempest Custom 421 SD clone KRE 74cc heads KRE 230°/236° hydraulic roller cam Rebuilt 3.23 rear end |
| The Following User Says Thank You to tempest1964 For This Useful Post: | ||
I used this Eastwood product for inside the frame.
https://www.eastwood.com/internal-fr...nozzle-nv.html
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following User Says Thank You to OG68 For This Useful Post: | ||
Osphos is available at hardware stores. Pretty similar rot the Eastwood product which has phosphoric acid also. Just did my 65 floor in it last weekend.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
One thing I regret not doing when I had the frame free was measuring to see if it is square. Mine was not - it was bent about 0.400" outward from an unknown crash. Would have been FAR easier to repair frame only.
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
This makes it easier to buy parts!
Happy with results? |
Hmm I'll have to look into how to measure for square on the frame. Interesting. |
It's in the 1st section of the CHASSIS SHOP MANUAL.
![]() It's an aerosol with a long wand that you insert into the boxed sections of the frame. Works fairly well in my experience. When you paint the frame it will cover any green thats showing. After priming, II used the Eastwood 2K frame aerosol for the outside of the frame.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ Last edited by OG68; 07-24-2026 at 09:51 AM. |
Where do you get those?
Most buy them used off of ebay.
Reproduction can be bought also, here from our sponsor may still have them. (haven't looked lately)
I believe our sponsor has them.
https://www.amesperf.com/parts/searc..._sub_rowid=404 Dang, too slow again!
Make sure you get literature for Tempest as Pontiac will reference the B-Body (big car). Also, ck out faxonautoliterature.com for publications Ames does not offer. Grab ALL manuals you can find as that is where the facts are from PMD, before improvements, of course.
Worth the effort! Not familiar with that specific kit, but I believe most allow you to run 315s on a 64-76 A body. If you plan on lowering your car like the white one in the photo you posted in your thread in the lobby, I would choose brakes, wheels & tires, suspension system, rear end, and transmission and mock everything up including, at a minimum drive shaft, engine and exhaust. This way you can modify the transmission tunnel and floors to get driveline angles and ground clearance where they need to be as you are making other repairs to the floors, etc. As Scarebird suggested, get the frame squared first though. In addition to Ridetech, you could consider Detroit Speed and Speedtech.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea Last edited by Gator67; 07-25-2026 at 12:11 PM. |
Great insight. Little more tear down.
On a 9 inch the pinion gear contacts the ring gear at the bottom. While the 9 inch is very strong it does require more HP to turn. A good choice if you’re not racing would be a Moser 12 bolt.
| The Following User Says Thank You to ANDYA For This Useful Post: | ||
#39
Consider using a Roadster Shop chassis.
It’s easy spending other people’s money I know. ![]() Also consider using the aluminum block instead of iron, one of the best reasons to use the LS platform along with the EFI. Knocking a considerable amount of weight off the front of the car was one of the main reasons I bought the crate LS3 for one of my projects. Ford 9” for sure, hard to argue against the ease of gear swaps, different gear ratios available and the strength of it. The couple extra horsepower it takes to turn it means nothing.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
#40
Is that right? Over $15,000 for the frame?
