Old 01-31-2012, 11:15 PM
lemans411's Avatar
lemans411 lemans411 is offline
no signs of detonation . actually running pretty fat. on e85. plus its intercooled . sd perf e heads 330 cfm " race port "
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #182
Old 01-31-2012, 11:28 PM
Travis Q Travis Q is offline
Hmm. Not sure. The Cometic stuff I've messed with usually sets in one retorque. How thin are the heads around those studs?
  #183
Old 01-31-2012, 11:33 PM
lemans411's Avatar
you thinking the heads are crushing? stupid cars. sorry for the hijack.
-Rob
68 gto
  #184
Old 02-01-2012, 10:02 AM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Originally Posted by cgeise View Post
Twin "hybrid" 88s and be carefull with the oil -- with it so high it really loads the drive components -- and if you have Ball Bearing turbos - -they dont like it and as was stated befor - 280 on the seat becomes 200 on the seat at 20lb of boost - just saying
Should we put a pressure relief valve in the oil line? What is the issue with high oil pressure? I think Tony wants this thing to be bullet(billet) 2500HP proof!
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
  #185
Old 02-01-2012, 10:16 AM
Originally Posted by lemans411 View Post
i have a 535 pontiac with cometics and arp studs. i have had issues with the heads lifting when i get around 20 psi of boost. when i check the studs they are loose... i have retorqued the heads many times and it seems the center stud that runs through the center 2 exhaust ports is always the loosest . followed by the outer bolts that run through the outer exhaust ports.... i guess im trying to figure out if they are just stretching or working their way loose . i torqued them right before the last race i went to and it seemed ok but really how many times do i need to retorque em before they stay? i assume your motor is dry decked? maybe i should o ring it and be done ... id be thrilled if i could get 25- 30 psi out of mine id be running 8's in a 4100lb car weeee!!!!!!!!
I believe that the biggest issue with your engine is probably heat. I am hoping with our improved water jackets and no siameze water jacket it helps with the sealing. All I know is his traction control better be hooked up.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #186
Old 02-01-2012, 10:19 AM
Anyone have the torque numbers for NA on these engines? I would say that is a better number since these engines dont have the compression or the header sizes to represent true horsepower?
I am thinking this dude is going to make big torque N/A.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #187
Old 02-01-2012, 01:29 PM
cgeise's Avatar
cgeise cgeise is offline
It is my understanding that with BB turbos you need a restrictor in the oil feed -- best talk to manufacture on that one --
  #188
Old 02-01-2012, 01:33 PM
cgeise's Avatar
It is my understanding that with BB turbos you need a restrictor in the oil feed -- best talk to manufacture on that one -- My BB stuff didnt last for **** -- just an FYI
  #189
Old 02-01-2012, 03:41 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
We’ll give Turbonetics a call and see what they recommend.
Are you running inline filters on your turbos? Which brand?
  #190
Old 02-01-2012, 03:44 PM
cgeise's Avatar
Nope - I live on the wild side - lol, although I dont remember if there are screens in the inlet or not
  #191
Old 02-01-2012, 03:53 PM
RAIV-Z's Avatar
Latest Pics from BES.
ID:	272985   Click image for larger version
  #192
Old 02-01-2012, 04:01 PM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
Ball-bearing turbos do not need as much oil pressure to lube the bearings as standard journal bearing turbos. Turbo manufacturer should have a recommendation of what to use for feed line (including filters and/or restrictors.)
Question for Travis. What do you use for boost control?
Panos
Little Miss G Racing on Youtube
  #193
Old 02-01-2012, 04:50 PM
cgeise's Avatar
at 44lb of boost - I dont think he is controlling it -- lol
  #194
Old 02-01-2012, 04:56 PM
tjwelter tjwelter is offline
Thumbs up motor
That looks wicked. Are those Moran / 500 lbs ?
  #195
Old 02-01-2012, 06:25 PM
We run Turbonetics 91mm BB Thumpers, and have never had an issue. We also run over 100 lbs of oil pressure, we use Royal Purple Nitro 50 engine oil. It is the cat's meow, for sure! Our oil inlet lines are unrestricted -4AN. Never an oiling problem, no turbo problems at all.
We use the boost control that's built into the XFI system, it works great. And yes Curt, I do control boost. A little bit. LOL!! In all honesty, I think we can make close to 50 pounds with these units, then we're going to run out. We leave with a lot, and try to make boost as quickly as we can, and use clutch, gear ratio, timing, and fuel to control power. With an engine that's only 480 inches with two big turbine wheels, we have learned that you are fooling yourself trying to control boost as a means of controlling power. We have to make boost quick and keep it there. Otherwise, the engine "falls off the turbo", and it's hard to get it to recover. If the engine were larger, or we had smaller turbine wheels like a GT55, we could probably utilize boost control a little more.
  #196
Old 02-01-2012, 06:26 PM
RAIV-Z's Avatar
Thanks, they are Moran 235lb injectors.
  #197
Old 02-01-2012, 07:08 PM
RAIV-Z's Avatar
Default BES Normally Aspirated Carb Break-in Results
660HP@5800RPM
675TQ@4800RPM
535cid
9.15-1 Compression
Camshaft [email protected] .701 gross lift, 115 Lobe Separation.
  #198
Old 02-01-2012, 07:23 PM
shaker455's Avatar
shaker455 shaker455 is offline
Any more info like carb used, jetting, timming & curve?
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #199
Old 02-01-2012, 07:40 PM
Bolt the turbos on, spool that big gun up and let her eat!!
  #200
Old 02-01-2012, 07:48 PM
cgeise's Avatar
On the flip side -- I do use gt55 turbine wheels on my 88s and control it with an AMS 1000 -- PROB APPLES AND ORANGES with an auto vs a stick . I dont know if the extra 45 ci makes a lot of difference? And its to damn much work swapping convertors - so we control boost a lot
