| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
| View Poll Results: Best Big 3 Truck. | |||
| Chevy |
103 | 47.03% |
| Dodge |
43 | 19.63% |
| Ford |
73 | 33.33% |
| Voters: 219. You may not vote on this poll | |||
Were these maintained engines? I do know they leaked bad but that was their thing. ![]() Popular Horsepower Ratings (8V-71) 866 ft·lbf @ 1400 rpm 318 hp (237 kW) governed at 2100 rpm 990 ft·lbf @ 1400 rpm 305-350 hp governed at 2100 rpm (turbocharged) 1064 ft·lbf @ 1200 rpm 305-370 hp governed at 1800-2100 rpm (turbocharged/aftercooled) 8V92 http://www.barringtondieselclub.co.z...oitDiesel.html
Brad,
You could be right. Most of the 8V92s we got were 350hp. In fact, we had a couple of late ones that were allegedly rated at 395hp. Either way, the 8V71,6V71s,8V92s,6V92s and 903 Cummins were successfully powering OTR trucks YEARS before emissions regs and fuel costs made them obsolete. Think HOW MANY Petes,Kenworths and Freightliners were built with these engines, ran WAY past 3000hrs (that's only about 2 yrs for an OTR tractor) and went to the scrap heap only because of federal and state emission regs and fuel became too expensive to use them anymore.
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
http://www.youtube.com/watch?v=Jp-qcZr_Wrw
Two 1975 455 Grandvilles & '79 455 Trans Am 69 Camaro SS 396/375 (owned since 88) 67 Corvette 427/435 23 Lexus LS500 awd 20 Audi R8 & 25 Toyota RAV4 (wifes cars) 95 Ford F250 4wd 7.3 p-stroke & countless Jeeps & off road vehicles & motorcycles |
Most of the time I see an aftermarket body for heavy use like the above it's on a Ford chassis. You type in "flatbed" on craigslist/e-bay and it's the same thing. There's a pattern -
If "V" diesels were no good you wouldn't see 'em in marine use as you said. As far as "undersquare" designs in a big rig think about it : height isn't a problem (stroke) in a long nose, but length is -
I have a 2005 duramax with 228000 miles only replaced an idler pulley. Just bought a new 2011 duramax, best truck ever to date. Fully boxed frame made a huge difference.
My truck plows with a fisher vplow and tows a 17000lb fifth wheel. Both trucks are 2500hd crew cabs. Bought a ford f350 once, it burnt to the ground overnight just sitting there. Never again. Chevy all the way
"The grass is always greener over the septic tank" Last edited by 70judgeconv; 02-27-2012 at 09:43 PM. |
bigunde,
That's 2 12V71s bolted together with LOTS of custom turbo plumbing. I saw it in "Hot Rod" late last year.
Brad,
The guy out in California we built the "K" series Cummins for had to lengthen the frame and doghouse 2 ft to make enough room for those monsters. 1,250 ci and 2,500 ci!! We couldn't get a reliable dyno reading on them, but best guess was around 550hp for the 1250 and 700 for the 2500. We had one guy the wondered IF you could fit a Cummins V-12 1710 into a truck chassis. That sucker is over eight feet long!!
The KTA was a huge sob; my great uncle had a Steiger Tiger he bought new in 1985. I can't even describe what a monster that thing was It's still in use today last I heard.
Brad,
Kinda of. It has a common crankcase with 4 individual heads (3 cylinders per head). BIG MOTHER!!
"he has more bolt offs than bolt ons" |
| The Following User Says Thank You to yak For This Useful Post: | ||
But here is a nice burnout attempt. Not quite one of those harmonic balancer destroying SRT-10's either. LOL http://www.youtube.com/watch?v=LCnwzGjhSBo
![]() The 71 seried Detroits were about the toughest most long lasting engines ever built. Their leaking IMO was also due to the fact from the factory Detroits were the most poorly balanced engines. He fails to mention some inline 6 diesels were known for crank failures as well (usually around the snout) and the V8 cranks tend to be stronger being shorter & more ridgid -
If you've ever seen the crankshaft out of a Chrysler V-10, you'll understand why!!
bigunde and Brad,
What we have in big hammer is the TYPICAL "throttle jockey". big hammer, you are correct: I am NOT a heavy equipment operator. I AM the engine machinist that had to repair all the damage that "gorillas" like you did to perfectly good engines because you're either too ignorant or too lazy to give an engine a LITTLE respect!! Oh, I've seen guys like you. You try to move loads so large the hydraulic lines nearly burst just to save a little time. You'll jump into a cold piece of machinery and expect it to perform flawlessly WITHOUT a single minute of warm-up. When all the abuse you have given the equipment catches up with you, you "bad-mouth" the equipment!! Like Brad pointed out, ALL Detroits( except the series 40,60 and 80 engines) are TWO-STROKES. Whether it's a 3-53 or a 16V149, they ALL operate at WOT. He(Brad) is also correct on the oil leaking problems. Those engines shake!! IF you change out the gaskets on a REGULAR basis, the problem goes away.BTW...I've got an uncle that is a retired operating engineer. He was operating heavy equipment before you were an itch in your daddy's pants. He's used Detroit powered equipment for years and NEVER complained, but he also take care of his equipment. Bud has a 1968 model D8 Cat that has NEVER had the bottom end rebuilt,even after the dozer sat in 10ft of water for a YEAR!! He farms, so he owns tractors. His newest tractor(a Massey Fergeson) is nearly 40 yrs old. It's NEVER had to have the bottom end rebuilt. See a pattern?
Why is he not suspended? |
![]() When the metal heats up it changes shape & expands, so hitting the throttle at startup won't change that - it will warm it up quicker is harder on the engine.
my comment about all ford motors is based on fact- none of them perform well out of the box from ford , they always need something done to them to make them perform. i used to be a ford guy but after having to work on their 1997 and up sh&t i dont even waste my time with fords anymore
