Old 03-28-2013, 12:25 PM
dci dci is offline
This rush is going to last a couple of days LOL!!!
Here is a couple with gaskets in place!!!
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 Shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air V heads !!!!!!
Name:	DCI 5 002.jpg
ID:	317804   Click image for larger version
Name:	DCI 5 003.jpg
  #182
Old 03-28-2013, 12:29 PM
428RA4's Avatar
428RA4 428RA4 is offline
Don -
It's interesting that you made the decision to cast the push rod tube foils into the head. I'm just wondering the thought process when you were designing the heads.
  #183
Old 03-28-2013, 12:59 PM
ho428's Avatar
ho428 ho428 is offline
Originally Posted by dci View Post
Here are a couple more!!!
Whoa, more Porn pics, cool...
  #184
Old 03-28-2013, 02:07 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Your RA-V heads look great Don, can’t wait to see a finished set!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #185
Old 03-28-2013, 02:38 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Originally Posted by 428RA4 View Post
Don -
Without speaking for Don, the factory style pushrod insert was an added obstruction to the port. With the ability to cast this requirement into the head, it allows for greater control in directing the air through the port. By casting this into the head, the port shape can be made to compliment the obstruction almost dividing the ports into two segments. Similar concepts are used on 4 valve cylinder heads.
Calvin Hill
Hill Performance
708-250-7420
  #186
Old 03-28-2013, 03:02 PM
ho428's Avatar
Calvin Hill
Hill Performance
708-250-7420
Hmmm, run the divider on down the port, put two smaller intake valves in along with a girdle in that massive valve cover area for an overhead cam, and...
  #187
Old 03-28-2013, 03:52 PM
428RA4's Avatar
Calvin Hill
Hill Performance
708-250-7420
Calvin -
Thanks for your thoughts. Though it may be a better control for airflow, I'm wondering if this design would limit your ability to port the heads. After all, it's now twice as hard to smooth out surfaces.
Old 03-28-2013, 07:04 PM
dci dci is offline
Like Calvin stated, it actually enhances the port. When I get time I will post more in depth pic's of the intake ports. All of my research and testing lead to my port design. When you see the actual port design you will see it actually is two ports in one. I found that by adding a vane to the roof and floor the port got happy.
Don Johnston
330-850-5050 Shop
330-628-3354 cell
  #189
Old 03-28-2013, 11:28 PM
Calvin -
No limitation at all.
Nothing a good carbide and some machining can't change IF you wanted to go back to the factory design.
As far as porting, using the right size tools will do the trick.
Calvin Hill
Hill Performance
708-250-7420
  #190
Old 03-29-2013, 01:11 AM
They turned out some nice castings !
Cast-In pushrod/port divider concept sounds real interesting too.
Don't tell anybody i asked ... but will BigBlok Chevy headers match the exhaust port layout ? Just wondering if their plentiful ready made headers could be incorporated.
  #191
Old 03-29-2013, 02:25 AM
Never mind
i googled some pictures of those headers .
woulda sure been convenient if they woulda been close
  #192
Old 03-29-2013, 10:42 AM
428RA4's Avatar
Knock yourself out...
http://www.ebay.com/itm/1969-1970-GT...3&cmd=ViewItem
Old 04-02-2013, 12:00 PM
dci dci is offline
Sorry it so long to get these posted. I went to visit my daughter in Tennessee for Easter over the weekend.
I shot a picture of one of the cad drawings as well showing the port shape. If you look close at the inside of the intake port. You can see the vanes I put in the port that are actually extensions of the pushrod tubes. Like I said earlier, by doing this the port got happy by limiting the turbulence the tube was creating. Obviously the tubes are larger than they need to be when cast, but that has to be to make the casting pour well. In an essence I created two individual ports behind the tube. They just share the same valve.
Don Johnston
330-850-5050 Shop
330-628-3354 cell
ID:	318297   Click image for larger version
ID:	318298   Click image for larger version
ID:	318299   Click image for larger version
  #194
Old 04-02-2013, 05:56 PM
428RA4's Avatar
Are you sure you are not an ear, nose and throat doctor?
Damn thing looks like a set of tonsils.
  #195
Old 04-02-2013, 06:58 PM
cgeise's Avatar
cgeise cgeise is offline
I was thinking of other body parts - but oh well
  #196
Old 04-02-2013, 07:12 PM
428RA4's Avatar
Just remember, all holes cost lots of money. Pick one that is right for you.
  #197
Old 04-02-2013, 07:57 PM
428RA4's Avatar
I have a serious question Don -
Are you going to put the spark plug holes in the stock position? I find it interesting that you have made the decision to not cast a combustion chamber. How does this all play out or is that still to be seen in post design production?
  #198
Old 04-03-2013, 11:10 AM
dci dci is offline
We do have a chamber design that I am going to start with. The reason for not putting a chamber in the head is to basically have a clean canvas to start from. Through the years of my cylinder head porting (30+). I have run into limitations with many of the different heads and their combustion chambers. It is really not a huge deal with aluminum heads because you can weld them up easy enough, but iron heads your limited. So I decided that I was not going to limit my head by casting the heads with a chamber. This way if someone is going to use nitrous or a blower which requires a different chamber configuration. They can design it with a cad program and it can be plugged into the cnc, and machined into the casting when they are being done. I want this head to be as versatile as possible and be able to cover a wide range of applications. I think with the separated exhaust port arrangement that this head has.These heads will not generate the heat in the center that our traditional siamesed exhaust port layout does currently. In turn should help the head gasket issues we have with the other style heads. Not to mention the extra thick deck surface I designed into these heads which will help as well.
The spark plug location can be changed as well and is not set in stone with this head. Spark plug location is very crucial in making maximum horsepower and this allows the engine builder to move things around to their liking. Usually the most ideal location is as close to the center of the piston as you can get it. I am going to try to get the spark plug in my off the shelf chamber as close to that position as possible.
Don Johnston
330-850-5050 Shop
330-628-3354 cell
  #199
Old 04-03-2013, 11:22 AM
dci dci is offline
I forgot to mention. You won't believe how many people have fingered the different orifices in this head LOL. Looking at the pic's and letting your imagination run wild. I guess I can see how one could enjoy feeling it up. I know I have LOL.
Don Johnston
330-850-5050 Shop
330-628-3354 cell
  #200
Old 04-03-2013, 11:30 AM
428RA4's Avatar
Well, you know as well as I, holes are meant to be touched. I think it's human nature to stick your fingers in things....;o)
Funny thing - A long time college good friend of mine had his son over the other day. As you can see, the 69 Trans Am hood has big scoops right up front. His kid could not help, but to slide both hands into the openings and feel around. That says it all.
So I would assume you have cut files for the CNC machine to cut chambers and spark plug holes? This is something that I would not want to tackle myself and would leave that up to a machinist expert like yourself.
I'm just a designer.
