Old 05-25-2016, 12:54 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Originally Posted by ta man View Post
Well we all had a good night at the track....everybody that was with us ran quicker, a Cpl fresh builds with no issues.As always traction was the key at this track.....my first run was my new best...11.30.18 at 120.58 with a 1.6509 60ft...next 2 runs were traction impaired but both over 120mph....my last run of the night..sorta surprised me...we thought the track was getting slippery..after a big burnout..ran 11.3223 at 121.35 with a 1.6798 60 ft with a slight spin.The car is definitely making more overall power..only once before has it ran in the 120's and that was wind aided.The only part that was changed from last year was the intake..jetting and timing remained the same...I did change the front squirter on the carb after first run...the car may pick up slightly with perfect traction..Big thanks to Pontiac Derek for the porting of this intake..it increased topend power but also kept the big fat torque curve.
Awesome progress and damn impressive MPH too ! What is your RW ?
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
  #202
Old 05-25-2016, 06:46 PM
ta man ta man is offline
I will weigh it soon..the old 80 TA weighed right at 3910lbs with me in it with half a tank...I haven't weighed the new car..it may come in at 100 lbs lighter,has a fiberglass hood,RobbMc starter,15 lb battery..and 15 X 4 Draglites with 165/85 M/T SR's...but has a lot of Dynamat..
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #203
Old 05-25-2016, 08:19 PM
Pontiac Derek Pontiac Derek is offline
Sorry to Hijack Ernie!
Take a 400,428, or 455 block, get it to 461-474cid
4.25" stroke, 6.800" rods, forged Pistons, good rings
Set Compression between 10.5 and 11.5:1
Use SD's Old Faithful on a 112LSA 108ilc for more low end
Or 110*ilc for more top end
Use Scorpion Short Travel Hyd Roller Lifters
SB 5/16 .116 wall pushrods and Harland Sharp 1.65" rockers
Get a Set of SD's 295-305cfm CNC ported cylinder Heads
Get an RPM intake, i Modify the Plenum and Port mine for more HP
But if you have no hood clearance get a Ported Torquer 2
And get a Holley XP 950, or any 1000cfm 4150 holley type carb
Use 1-3/4 Long Tube Headers, and a Good HEI Dizzy
Trans-Build up a 350 or 400 trans, and if manual use a Strong 5-6 speed!
use a Jim Hand Special
Continental or Similar 32-3500 converter with Anti Ballooning plates, of course if you can afford an Overdrive Trans Go For It
Then either Build up a 8.5" ten bolt or get a Dana 60 or Ford 9"
Minimum Gear Ratio would be 2.73-3.08, Max would be 3.42-3.73 with overdrive trans
A good fuel system, Roll bar, and some Sticky Tires
Should Be enough to get anything under 4500lbs into
The 11's!
The "Old Faithful" Combo :-)
Im done highjacking, sorry!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #204
Old 05-25-2016, 08:20 PM
I bet you are at 3850lb area, im so jealous of you lightweight guys! 4600lb Race Weight Here lol
  #205
Old 05-25-2016, 10:14 PM
slowbird's Avatar
slowbird slowbird is offline
The 11's!
When did SD come out with the OF cam?
  #206
Old 05-25-2016, 10:37 PM
Torquewar's Avatar
Torquewar Torquewar is offline
What does Andy's car weigh?
Well dont know what it weighs...basically aluminum heads/intake /rad .
Stock TA body PW /PL/ but have a heavy 3 exhaust and add some weight with Cal tracks.
Weld Rims for race. So with me (225) im guessing 3900+
Yes the Old Faithfull combo with a few tweaks.
Happy yes ...but lookin for more
  #207
Old 05-26-2016, 02:10 PM
I think Dave Started Using that cam in 06-07 iirc but i can't remember
  #208
Old 05-26-2016, 02:11 PM
Yeah and he Hit 121.35 mph on one pass!
  #209
Old 05-26-2016, 02:20 PM
Nice! Yeah you will get there, its hard to get your car fully dialed in when ya change several parts but i think you will end up doing really well
What do the Heads Flow now? How Big is the Port Size and what Intake gasket will you use? Sorry im just trying to calculate some things, even though i build engines Do Port Work and Manifold work i Am still learning new things everyday, i have learned you should listen to everyone!
  #210
Old 05-26-2016, 04:15 PM
77 TRASHCAN's Avatar
So Ernie,
I believe you've mentioned here, or another thread about getting you car into the 10's. What's your thoughts about what path you might take to get there???
I'm asking this, as you are ironing out your return to the T2 intake, and such...
Shut it off
Shut it off
  #211
Old 05-26-2016, 06:08 PM
Originally Posted by 77 TRASHCAN View Post
So Ernie,
Never really left the Torker 2..only for a Cpl months last year.
Without swapping gearing and convertor..it is a challenge..For this year I'm just concentrating on the 60 foots..a squirter change last time seemed to quicken initial throttle response so more carb tweaking,subtle suspension mods(I do still have stock suspension other than CE 3 ways),increasing initial timing and more minor weight reductions.I have thought about increasing compression..but I don't want to mess with the heads for a future project,pulling off my 2.5 tailpipes for possible restriction and weight savings,installing proper relay and wiring for my fuel pump and rerouting lines ,installing a shiftlight for consistant shifts,installing a line lock for consistant burnouts.
I really need more track time...wish I lived closer and had more time!
I'm currently just trying to do it the hard way...I enjoy the challenge..just when I get stumped or stalled another idea comes along..
I'm always open to test any ideas too..as Pontiac Derek has found out...keeping an open mind helps..
  #212
Old 06-06-2016, 06:45 PM
Posted this in the exhaust section too..I pulled my 2.5 inch PYPES tailpipes with splitters off last night.I want to see if there is a restriction...Cheap mod plus I dropped 20lbs of weight.It also gives me some room to reroute my fuel lines and hang my fuel pump a little lower.So my current exhaust consists of 1 3/4 inch Hooker Super Comps,3 inch PYPES X crossover,into 2.5 cone reducers into 2.5 inch Walker Ultraflows to a set of turndowns..
  #213
Old 06-06-2016, 07:56 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I think at your power level you'd benefit from 3" exhaust.
  #214
Old 06-07-2016, 07:02 AM
Looking to get in the 11.2's this year...Pontiac Derek's intake really helped drop et and gain mph..now just some tuning and cheap changes..
  #215
Old 06-13-2016, 10:35 AM
The Great thing about Cars and People Like Ernie, Cliff Ruggles, Dave Bisschop, And Jim Hand is if its the only thing you learn from them its that it takes Tuning, Driving, Racing and Testing in General to Maximize the Efficiency of your Combination!
Just bolting stuff together no matter how scienced out it seems you will not realize the full potential of your Setup!
This is not important to everyone, but its important to a lot of people and Nothing is better than some Yokel telling you thats impossible! Cant be done! Not with a Pontiac! Oh Yeah? Hmmm ;-) Watch Me!
  #216
Old 06-13-2016, 02:55 PM
Weather permitting I'm hoping this weekend to do some testing with no tailpipes...the next test after is a main body switch on my 950hp...switching to a 1050 mainbody with annular boosters.Hoping to do 1 or 2 track days a month for the rest of the year..
  #217
Old 06-13-2016, 04:17 PM
71 T/A 71 T/A is offline
I think you'll pick up a tenth and realize your goal of 11.20s. Are you using a modified Torker 2 now?
  #218
Old 06-13-2016, 06:12 PM
I agree on the 11.20's..if the traction isn't there the mph will show the results..
Yes I picked up about a tenth and a 1.5 mph with a Torker 2 prepped by Pontiac Derek..before it usually ran 119's..ran one 120 with a good tailwind...last time at the track all 120's with one 121....just with the swap from a gasket matched and blended back torker 2 to the current Torker 2..everything else the same including jetting.
  #219
Old 06-13-2016, 09:37 PM
grandville455's Avatar
grandville455 grandville455 is offline
11.20's? Y stop there!!! keep tuning that bad mutha lol
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #220
Old 06-13-2016, 09:48 PM
The Torker II seems to get overlooked by most unfortunately.
I won a lot of bracket races with a low-compression 455 topped by a stock Torker II and 650 DP Holley. I was nice getting some contingency prizes from Edelbrock too when I was winning.
It's a damn fine intake, especially so if Derek hits in just the right places with his grinder.
Nice going guys, the train just keeps on rollin'.
