Old 12-06-2021, 10:56 PM
David Holmberg's Avatar
Awesome build Erik!
Old 06-25-2022, 04:12 PM
73 TRANSAM 73 TRANSAM is offline
Tom,
He bought it from VS racing.
Old 12-07-2021, 02:57 PM
ErikW's Avatar
ErikW ErikW is offline
Thanks guys
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 01-02-2022, 10:18 PM
ErikW's Avatar
Default More Progress
So, while I'm cutting and buffing out the paint on the Bandit, Nick is fabbing up some cool air ducts for the turbo compressor inlets, They utilize the existing cut-outs in the front bumper.
ID:	581278   Click image for larger version
ID:	581279   Click image for larger version
ID:	581280   Click image for larger version
ID:	581281   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 01-02-2022, 10:26 PM
ErikW's Avatar
Default More Pics
I'm also adding a temperature/humidity sensor from a Mack truck air intake so I can monitor weather conditions. Utilizing Holley's software I can add a math channel to my tune file and have it spit out real time density altitude based on this sensors readings and my input of track elevation. Bandit will be it's own weather station. Pretty cool!
ID:	581284   Click image for larger version
ID:	581283   Click image for larger version
ID:	581285   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 06-21-2022, 06:18 PM
Tom Vaught's Avatar
Boost Engineer
What did you pay for your Turbos?
Hope you have enough cash to purchase another set.
I did the air scoops "down low", (copying the Olds 442 1966 & 1967 Ram Air cars, but I had the air feeding a circular Ram Air "Box".
https://www.ramairbox.com/ The air cleaner had a filter.
I was amazed with how much road trash the scoops collected and transferred to the Air Box. A cup-full at times.
In your case I see no filtering system prior to the Turbocharger compressor blades.
Maybe you have some screening that was not visible in the pictures.
Hate to see a new set of Turbos trashed and needing a rebuild minimum because you killed your turbos.
Big Chief got his turbos for free from Precision Turbos (so if the Oklahoma grit kills them) he can get another set.
Food for thought.
Tom V.
Old 06-24-2022, 10:56 PM
ErikW's Avatar
Default Back to work on the Bandit
Sooo, The car has been down for a good part of the year since Drag Week 2021 and our lifter demise. Upon tear down and inspection of the block we elected to machine up a new block as we had found a small crack on the parting line of one of the cylinders that experienced a little interference with the piston and needle bearings from the lifter exploding. Thankfully all pistons checked out OK. So while the engine was back out of the car, Nick decided to modify the front frame to allow oil pan removal. He jigged up the lower control arms, cut out the frame x-member and fabbed up a new x-member and forward attaching points for the lower a-arms. Now we can drop out the center and remove the oil pan for inspection.
ID:	593254   Click image for larger version
ID:	593255   Click image for larger version
ID:	593256   Click image for larger version
ID:	593257   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 06-24-2022, 11:38 PM
ErikW's Avatar
Food for thought.
Tom V.
Unfortunately, air filters are super restrictive on the front of turbos, but we do have screens to keep out low flying birds and some debris. Also at 750.00 ea. Its not too hurtful to replace one. Don't have Big Chief money or sponsors.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 08-16-2022, 09:13 PM
Nice talking with you guys at Norwalk last Saturday. I'm the one who asked about your custom trans pick up assembly. Good luck with your quest for a low 8's in ur car.
The Following User Says Thank You to 73 TRANSAM For This Useful Post:
Old 01-06-2022, 07:18 PM
R 70 Judge's Avatar
Very cool. Nice fabrication. I wonder if they will be worth anything ET wise?
James
1970 Trans Am
Old 07-06-2022, 10:09 PM
Thats a very nice looking TA you have there. Are you going to be at Norwalk?
Old 07-07-2022, 04:44 PM
ErikW's Avatar
Yes, we'll be there
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 07-17-2022, 08:13 AM
ErikW's Avatar
Bought a Cricut machine and added some custom touches to the graphics. Attended a track rental on 7/14 and just worked on the 60ft times. We managed to get her from an initial 1.32 down to a 1.18 before we got rained out for the day. Previous best has been 1.26 at Norwalk during Drag Week 2021. Looking for low teens or high 0's. Between lauch boost, tire pressure and shock settings we are closing in.
ID:	594467   Click image for larger version
ID:	594468   Click image for larger version
ID:	594469   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 01-18-2022, 03:08 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
What does your car weigh? Killer work guys!
69 Firebird - Angry Bird
455 with 84mm Torqstorm
Old 01-19-2022, 01:18 PM
ErikW's Avatar
3460 or so with driver.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 06-20-2022, 12:22 AM
R 70 Judge's Avatar
Erik, do you mind posting some info about the turbos? I read 78/75 but didn’t see much else. I’d appreciate it. I may be jumping off the deep end and doing this soon. Thanks
James
1970 Trans Am
Old 06-24-2022, 10:46 PM
ErikW's Avatar
Getting ready to update this thread. I have tons of pics to upload. The turbos are VS racing 78/75 T4 units https://turbo4less.com/product/vsr-n...n-7875-billet/
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 06-25-2022, 12:53 AM
R 70 Judge's Avatar
Thanks for the turbo info. Your car is so bad ass!!
James
1970 Trans Am
Old 06-25-2022, 05:46 PM
Tom Vaught's Avatar
Boost Engineer
If you are not planning on running boost above 18 psi, most of the decent Chinese
offerings will do the job with either a sleeve bearing supporting the compressor/turbine shaft or sometimes there will be a ball bearing option that is not too expensive.
Key is the boost pressure/load exerted on the compressor/turbine shaft.
I looked at the website. The people are a Marketing outfit. Not a Turbo Manufacturer
like Borg Warner or Garrett. But they still might have access to some good parts.
Richard Holdener has lots of videos on different turbos he has tested over the years.
And he and his wife are very nice people. https://www.youtube.com/channel/UC8u...63l1-uRSx6XbnQ
Tom V.
I am disappointed though that no one in the pontiac world was willing to loan him a 57-58 Pontiac flywheel so he could run a older Pontiac engine with a turbo on it.
Old 07-01-2022, 04:02 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I might need a poster of this car when its done. The paint and graphics, like everything else, look fantastic!
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
