#241
i have the same tank in my 72 & am debating on buying the drop in pump vs the whole unit with their tank. but if it requires an extra insert welded in i would opt for the whole tank set up. |
#242
There is a recess in the top of the Tanks Inc tanks that drops down about an inch or so. I would also imagine the recess that CNC had to weld in also came with baffling, at least I would hope so, because the Tanks Inc tanks are also baffled in this area.
The recess is there for a couple reasons that I can see. One is to have the pump reach the bottom of the tank as these Walbro pumps only come in one length, at least the ones I've been buying. The typical 20 gallon EFI tank from Tanks Inc is about 5 inches deep, as that's how they list them for their sending units. They do offer a slightly deeper version for the 2nd gen F-bodies, which I just installed in a car here. 22 gallon I think it is. The other reason is that it allows room to have your fittings and lines on top of the pump, otherwise they would be smashed against the trunk floor. I highly recommend opting for the whole tank setup. It's baffled, the sump is there ready to accept both the pump and sending unit, it's powder coated and ready to go. Plus it's cheap enough to make the decision easy. If I have to do welding on a tank, either adding a rear sump or adding evap lines etc.... I always start with a new tank anyway, EFI or not. Just not worth messing with these 50 year old tanks. |
#243
Wish I could go with you Ernie...not in the cards. Get that thing down the track...
I will chime in on the fuel system deal. I went to the Aeromotive in tank stealth system guessing 5 yrs ago. It’s been flawless but it does sit against the trunk floor so not perfect. To do it again , tanks system with there tank all the way. CNC did have a little war adapting his deal as he mentioned. |
#245
The fuel pump outlet is very close the outlet Port of the assembly ....were u join the two pieces together with the small section of hose... If u were to mount this setup directly to the top of the tank without the insert I bought ....I'm not sure how far down u would have to space it and not have neck interference issues at the rear Lic plate area ...plus longer tank straps...those I used the originals....u can see the one pic the fuel fitting is just above the top of the tank .... I would do the tank unit from Tanks inc.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 10-24-2019 at 08:13 PM. |
#246
Heading to Cayuga Saturday should be a good day. Installed the new pump had to turn the regulator down..something sure was funky with the old one.
#247
#248
No prob on the pics
Ernie get that thing down the track and let us know the outcome ...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#250
Thanks all for information. Glad to know improved, reasonably prices fuel systems can be had these days. I am helping my brother with his 73 Camaro, currently, assemble the fuel system on his car. Got a new tank for it about 10 years ago, had it "sumped". My good buddy, that can weld ANYTHING, had a frustrating time doing to job. The newer tanks are likely an aluminumized steel of some sort. It looks great, but was a bear to get the job done, he said. He said he could not charge me for the job, because he feared of leak potential. He told use to use some kind of tank sealer coating in it (which we did).
We also bought an Aeromotive pump and filters, and regulator (return type system), which are quite pricey, but quality seems to be top notch (I've never heard anyone here talking about issues with one of their pumps...). So, we are over committed $$$ wise to using this system. Now just a matter of plumbing it all up...I knew his exhaust was an issue. He has a very nice Flowmaster complete transverse muffler system. The muffler made it nearly impossible to route lines AND mount pump close to bottom of tank. Went to 2 DynoMax mufflers. Man this is a lot of work, and money. (His money...)
#251
Does that trough help gather fuel at acceleration?
#252
Made it to the track yesterday..nice cool day. Good for et's. New fuel pump nice and quiet steady fuel supply.
First pass basically a duplicate of the last weeks..11.4/118mph...but this time I actually looked at the tach at the stripe..it was pegged..so with my tach being off slightly it was at least at 5800 rpm. So if one does the slippage math its about 24% not good. I was expecting a bit of loss at the topend using this convertor but not this much. I'm pretty sure its the convertor slipping..but maybe possible transmission issues as well?...but it shifts fine seems to work well no burnt fluid. Since winter is here..I think my plan is swap the 3.42's in. Take the tranny to my tranny guy for an inspection and also send the convertor back to UCC for a checkup. On another note..finally putting full safety equipment in the car, I need to be able to test the car at any track without issues and for my own safety. I'm also going to register for DragWeek for 2020..since it is so close for me..its on my bucket list so nows the time.
#253
So this was a new track for me this weekend and last weekend..and it was great to go to a different track , see different cars and meet new people and share stories and experiences. Always a good time!
#255
what converter did you have before the change to the UCC? was the previous converter in there for your best/better 10.7 passes? if you didnt change anything else, sounds like its the converter hurting the times.
#256
Continental 10 inch 3200
#257
close to the same one i'm running. wish they were still around.
#258
Sorry i haven't read all the post, is the UCC converter built for your car or bought used?
#259
It was built for my car..but for 3.42 gears.
#260
Wow seems like something is not happy then.
