And doing this with pump gas while not overheating in traffic, hard to beat a well built Pontiac! Plus we actually work harder on our stuff to squeeze more performance and reliability than your average Chebby guy.
TA Man could go to 3.42 gears and a little more stall like 3500-3800. Of course that means more traction would be needed. You're never done in racing and that's a good thing.
Yes that's a given with traction more stall and gear would get it there..I'm enjoying the tuning process too much ....trying to get as much out of the basic combo as I can.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
Why mess with a perfect street performance combo?
A 400 stroker with a 3-speed auto, doesn't get much simpler than that. Runs 11.20s with 3.08 gears. Great out on the highway and the track too. Drive it anywhere, anyplace, any time. Not many guys ever achieve this, hopefully more will carefully study this thread and follow suit. This car is perfection.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
How much does the rear and passenger seats weigh? And the front sway bar? Bet you would get the 2 tenths that way, that's probably close to 100 lbs.
Nice idea..I still like it looking like a car inside!Would probably take 200lbs for 2 tenths....I've thought about the swaybar and may try it again...the old car I took it off for a bit..I like how it handles and leaves flat with it on..but weight is weight..and it may help the launch a bit...I know if I'm knocking on 10.99 the seats will come out!
In today's Muscle Car era........it's not his fast you are.....Its How You Sound !!!
Fyi, there are guys running well into the 10's with 3.42 gear, most likely would still run tens with 3.08.
Its Experimental Territory if he would like to purse 10's N/A with 3.08's.
3.23 , 3.42, 3,64( Old Buick GSX Gearset & Pontiac Fullsize 9.3 only), 3.73 & 3.90 would net easier results I think. 3.23& 3.42 fully streetable. |
^^^Truth^^^
I did back to back on my TA just with the sway bar unhooked not off and no difference in hooking and sure did sway making the turn around at the end of the track.
Front skinny tires made a bigger difference than just the weight loss with them I guess rolling resistance.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I notice we never do Racing math here on Max.
And I like All engine parameter math, calculus, & drive train math. Break it down so all can understand. Coming up next. |
The engine is a Hot Street Strip 455 -463 with modern aluminum race heads, stump puller torque cam, 575 ft/lbs peak torque at the flywheel.
Rear diff Gear. Turbo 400 1st gear . 575ft/lbs flywheel torque. __________________________________________________ _______ 3.08 X 2.48 X 575 = 4,392.08 ft/lbs delivered to rear tires- pavement on launch. 3.23 x 2.48 x 575 = 4,605.98 ft/lbs 3.42 x 2.48 x 575 = 4,876.92 ft/lbs 3.64 x 2.48 x 575 = 5190.64 ft/lbs 3.73 x 2.48 x 575 = 5318.98 ft/lbs 3.90 x 2.48 x 575 = 5561.4 ft/lbs 4.10 x 2.48 x 575 = 5846.6 ft/lbs 4.30 x 2.48 x 575 = 6131.8 ft/lbs 4.33 x 2.48 x 575 = 6174.58 ft/lbs 4.56 x 2.48 x 575 = 6502.56 ft/lbs |
4.88 x 2.48 x 575 = 6958.88 ft/lbs
5.13 x 2.48 x 575 = 7,315.38 ft/lbs 5.38 x 2.48 x 575 = 7,671.88 ft/lbs 5.57 x 2.48 x 575 = 7,942.82 ft/lbs 5.86 x 2.48 x 575 = 8,356.36 ft/lbs 6.14 x 2.48 x 575 = 8,755.64 ft/lbs |
That car was meant to do one thing, go straight. |
So is that the general/baseline math, 10th of a sec for every 100 lbs?
Thing with gears, cam selection needs to be in line for any gain there. Isn't it something like you want to be a peak HP RPM as you cross the line? .
You want to be at Peak HP At 1320 foot mark. Or at 1000 foot mark and cross 1320 mark 200-400 rpm. Over. Not over rev the engine. Hydraulic Roller cams don't like being over revved. Stuff breaks fast. |
Big torque engines like Pontiacs can cheat some.
But chasing down Tenths with available parts now. Weight reduction can be done also. Becomes less of a street car. More like a gutted Race Car. |
