Old 06-12-2016, 05:44 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
Trunk mat made from an old wagon cargo area may I had
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
  #262
Old 07-03-2016, 05:38 PM
GTOWAGON's Avatar
Ok here's a brief update
I have been driving the car for 2 weeks now and about 300 miles
Still runs a bit rough but that will be fixed when I get jets (I need a lot of jets)
Car drives well a little scary on a grooved road but it has bias plys so I expected that
I have had to play with the rear suspension a bit as is was binding but that's fixed and made a big difference in the ride quality I have to weigh the car and see if I need less spring in the back.
2015 GMC Yukon SLT
  #263
Old 07-04-2016, 02:07 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I sure am glad you didn't "give up" on it awhile ago. I look forward to seeing it not on a trailer! How about driving the old Watkins Glen race course in it this fall?
  #264
Old 08-07-2016, 01:06 PM
GTOWAGON's Avatar
Passed the 1000 mile mark today
So far no major problems did burn up the electric fan but got a much better one car will run at 180 all the time unless sitting in traffic so the fan dosent have to do much.
2015 GMC Yukon SLT
  #265
Old 08-14-2016, 10:20 PM
Engine-Ear's Avatar
Thanks for the updates!
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
  #266
Old 09-04-2016, 07:55 AM
Jeff Hamlin's Avatar
Thumbs up 2016 PYPES SHOW
Chris just finished the latest Poncho Perfection.
Congratulations on some nice ink,
Car Looks Great!
  #267
Old 10-03-2016, 07:35 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Car Looks Great!
Car looks great!
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #268
Old 10-03-2016, 07:58 PM
GTOWAGON's Avatar
Thank you
I will have the car finished for the next pypes show
2015 GMC Yukon SLT
  #269
Old 02-06-2017, 07:07 PM
brut4s's Avatar
brut4s brut4s is offline
Updates?
  #270
Old 02-06-2017, 07:46 PM
GTOWAGON's Avatar
Busy winter for me I have been working on a couple cars for other people. My friend toms 71 lemans convert just got into paint shop so I am back on the coupe. I hav a couple problems last year that caused the rings to get gas washed so I had to get the short block reringed. I just got the short block back next weekend and will be getting the engine back together and back in the car soon. Changes I am making are
Converting the lash adjusters to a regulated external feed
Upgrading the ignition to a mad 6al2
Redoing the headers and exhaust system to a 2 1/2" dual
New cam is a reground h320 from crane
New 3.90 rear gears
Plus a finished interior
2015 GMC Yukon SLT
  #271
Old 02-06-2017, 08:17 PM
brut4s's Avatar
Nice!!
  #272
Old 03-05-2017, 02:40 PM
GTOWAGON's Avatar
Doing a little work on the coupe this weekend.
just finished up the headers
got the block drilled and tapped for the oil return on the external lash adjuster regulator
Found this neat little aluminum freeze plug that has a 1/2 not hole in it for my temp gauge
and got started on the vacuum takeoff for the Webber intake so I can run a pcv valve
ID:	448827   Click image for larger version
ID:	448828   Click image for larger version
ID:	448829   Click image for larger version
2015 GMC Yukon SLT
  #273
Old 03-05-2017, 10:48 PM
brut4s's Avatar
I wish there was a like button on here!
  #274
Old 03-12-2017, 01:33 PM
GTOWAGON's Avatar
The new collector stubs are done old is on the left new is on right
ID:	449399   Click image for larger version
2015 GMC Yukon SLT
  #275
Old 03-16-2017, 11:19 AM
GTOWAGON's Avatar
Had a snow day on Tuesday so I had time to make a bracket for the lash adjuster regulator and decided to rebuild the hurst comp plus shifter
ID:	449764   Click image for larger version
2015 GMC Yukon SLT
  #276
Old 03-16-2017, 07:28 PM
GTOWAGON's Avatar
Got my hurst shifter put back together and finished up this tubing nitemare for my PCV system
ID:	449842   Click image for larger version
2015 GMC Yukon SLT
  #277
Old 03-16-2017, 09:23 PM
Engine-Ear's Avatar
man, that last pic is badder than old King Kong!
  #278
Old 04-29-2017, 07:25 AM
GTOWAGON's Avatar
Ok been getting some stuff done still waiting on new custom grind cam but carbs are rebuilt and drilled and pinned the linkage arms to the shaft. Oh and here's a pic of Godzilla made from old tires just because Godzilla is cool
ID:	453343   Click image for larger version
ID:	453344   Click image for larger version
2015 GMC Yukon SLT
  #279
Old 04-30-2017, 03:31 PM
GTOWAGON's Avatar
Ok getting closer all the interior panels are fitted and mounting holes punched just have to drill and tap holes now only 34 not so bad
2015 GMC Yukon SLT
