#261
GTO George |
#263
Course there have been cases like the Daddy Dave Truck where the owner had some tuning issues over the past couple of years. When Dave was driving, the truck looks like it was on a slot car track set of rails. Very impressive for sure. Tom V.
#264
Pretty much all this proves is turbos with a little nitro mixed in can make any head look good. Makes you wonder how fast a set of iron d-port or round ports could go with turbos.
Disclaimer, you have to know how to get the car to work and apply the power and chief and crew most differently know how to do that. |
#265
If it's that simple you should strap a couple of hair dryers on your hi-ports and show the world how it's done. 3.50's should be a slam dunk!
#266
GTO George |
#267
I'm sorry....didn't mean it like it sounds....I was just helping you get your car in the 3's. Lots of people talking about the Eheads not being that good....but no one is stepping to the plate.
#269
Didn't mean to be a jerk....Justin skull dragged every other car at Indy running stock style heads like he has.
#270
After 700 hp on the street it becomes very hard to hook a car. Those guys know how to tune a suspension and yes there traction control helps but they are good, real good.
Last street race I was at 2, 8 second cars, 1/4 mile race, wow they come by fast on the top end. I know some do not like it but it is impressive to see cars hanging the front tires for 300 feet on the street. The 405 takes it to a real high level. I do like fast small tire cars better. It's even more impressive. |
#271
some of them do, I know the sonoma did.
#273
Sorry I couldn't help myself. GT. |
#274
GTO George |
#275
George, if you changed fuel in your car and cranked up the boost how fast would you run? |
#276
Dyno numbers are only numbers. I've rarely seen dyno numbers equivalent to the same numbers on the drag strip. The e-heads have decades behind them and because of that there are far more racers with e-heads on there cars. As for one off billet heads except for the Visner all the other heads can be bought in cast form. Speed cost money, most Pontiac racers are cheap, only few are willing to set it out (money & time), the ones that do are rewarded. Butler , KRE, Cooper, Welter, Justin, etc. all have a lot in common.....not enough time or money.......no MEGA company's here! You wanna go fast how much time & money you got......it's pretty simple. E head can't compare to the Warp 6. Visners CV head, DCI RA5 head are two heads with more time on them WILL easily surpass the e heads.
My engine runs on alcohol.....what ifs are silly! I'll run any car with any head, anytime....same boost, same weight....same day....same strip with my HP heads. I'll be at Norwalk. ![]() GTO George |
#277
![]() Btw... I doubt I'll be at Norwalk |
#278
#1 Warp 6 - limited availability #2 our billet RA5 - not available, built for ruggedness, not ultimate flow #3 Tiger heads #4 e-heads #5 (I don't recall) #6 E-heads #7 Tiger #8 Warp 6 #9 Warp 6? #10 Warp 6 So 4 different heads represented....a nice variety in my book. Eric
#279
#280
Way are these not readily available? Stan
