Old 08-11-2015, 07:48 AM
The Boss's Avatar
The Boss The Boss is offline
Congratulations, welcome & I must say that's a spectacular 1st post!
The odds that the original owner spun a bearing or threw a rod in the original motor are very high when you take into consideration the M21 & the 4:33's out back. A lot can happen to a car in 45 years and these cars were built to be beaten on.
If you have a chance, e-mail me a pic of your WY stamp and EUN - I've been keeping track of them for years. Also, I'm guessing your car was a Pontiac Plant build? Is your block an As-Cast C118 2506 block or is it ground & stamped with the 2506? An early build like yours would have come with an as-cast block.
[email protected]
And go racin' in the street.
  #302
Old 08-11-2015, 01:10 PM
PurelyGTO68 PurelyGTO68 is offline
Originally Posted by olgoat1 View Post
Recently purchased 1968 RA II GTO from Wisconsin. This car went to Seltzer Pontiac on north side of Chicago, I purchased car from 2nd owner who said the previous owner would not tell him much about the car, just that he was the original owner and it had the original motor, but the motor in it was a early 68 WT motor, and the trans was an M20. Obviously this is hard to understand.
The man I purchased it from got it in 2005, ran the PHS and it was a RA II Verdoro Green, black vinyl roof, black interior, 4spd, 4.33, PS, PDB, AM radio but no antenna?, Rally IIs, console, remote mirror, ride and handling. Build date was 5/31/68. Body date 5D.
I have the correct WY motor and RA II stock heads and correct M21 and checked the axle code and it is ZL.
Would appreciate any information about the early history about this car if anyone from the Chicago area knows anything about it.
Welcome to the club! I recently joined as well and have found this site to have a ton of valuable info about these cars. I am still reading old threads with much interest.
I have the sister car to your vehicle. Invoice date May 27, 1968. Verdoro green, black interior, black folding top, 4 speed. It is a project right now....will be starting on it later this year.
  #303
Old 08-25-2015, 10:17 PM
olgoat1 olgoat1 is offline
Default WY motor details
The WY motor I have is D248 cast date with a 751408 MU# and there is no serial #. The 2506 is ground and stamped. I have an M21 with a P8E03 code and wondered what codes have been seen in the RAII GTOs built around the 5/31/68 date? Thanks
  #304
Old 10-03-2015, 04:00 AM
Gtowolf Gtowolf is offline
Default Rally stripe
It's the stripe I described...a double pinstripe at the lower body line running from the front bumper to the rear. My first '68 had one but I don't have a pic of it where the stripe shows clearly. You don't see many cars with them.
About the only pic I could find is of this MODEL car. Of course, the stripe is a little 'off scale', that is, kinda thick compared to the actual car.
Coincidentally, this model is exactly like my first GTO. Mayfair Maize with black interior and black Rally Stripe.
This is the best pic I can find of my old one from '82. You can see the stripe at the lower front fender..
Would anyone have pictures of the Rally stripe up close or some info on installing the stripe ...I am putting on my car...TY
  #305
Old 10-04-2015, 08:51 AM
The Boss's Avatar
From post 287.
There are three AS-CAST 2506 dates that we have on record as of this date.
J177, L187 and C118 - the first two dates being exclusively for the Ram Air I motors but the C118 date was used for I's as well. As for the C118 blocks in II's, they have been found as late as an invoice date of 06/24 in the Baltimore built Alpine Blue MIA body however I also have records of an E278 Ground & Stamped WY block in a Framingham built car also invoiced on 06/24. I have records of an F148 Ground & Stamped WY as well.
Where the cutoff came for the ground & stamped cars I don't quite know however both my & Ross's 05C built Pontiac Cars will have C118 As-Cast blocks in them and based on what I've seen, yours should as well.
  #306
Old 10-04-2015, 11:26 PM
Page 91 in the '69 Factory Assembly Manual. It's not real clear but you can make out the measurements. You may know this already but the stripes are painted on.
Old 10-05-2015, 12:35 AM
A decent representation for the effect.
From nose to rear bumper.
Name:	68 GTO convertible 2.jpg
  #308
Old 10-05-2015, 12:40 AM
70pontiaction 70pontiaction is offline
Smile Information accumulated regarding cast/stamped 2506 blocks and date codes:
I currently have (two) 9792506 Service Replacement RAII/RAIV blocks.
The first has the as-cast 9792506, stamped SR862xx and has a casting date of C118.
The second is cast 979, ground and stamped 2506, stamped SR892xx and has a casting date of F179.
  #309
Old 10-05-2015, 06:58 AM
The Boss's Avatar
Thanks for the info - I may be wrong but I think that's the first AS-CAST 2506 SR block we've come across. Most that I've seen have been ground & stamped.
Being that it came out of the inventory used for both I's & II's I'm going to guess it was originally ordered for the replacement of a I engine blown with it's 4:33 gears but it also could have been assembled for inventory to be used on a II.
The second one from F179 is likely more valuable as a IV replacement than a II but could have been used in a I, II or IV car at any time. The original block from my RA I/Auto car was blown in 1976 according to the original owner so anything was possible.
Either of those would be good replacement blocks for the two new cars identified above.
  #310
Old 10-05-2015, 01:14 PM
Smile I wondered if there had been other 'AS-CAST' SRs located.
I think just about every SR 400 block I've run across up to this point was ground and stamped - some just the last digit, some a couple and some all digits. Both of my 1970 RAIV SR blocks have just the last digit ground and stamped, and I've seen a few with the entire 9799915 ground and stamped. And several factory 'numbers' 70 RAIV blocks I've seen had the last digit ground and stamped.
I wonder if this 'AS-CAST' SR block might have been sold over-the-counter as a 400 block with 4-bolt mains to someone who was just wanting to upgrade or purchase a high performance 400 in 1968? Or a drag-racer? Guess anything is possible.
I wasn't really into Pontiacs at that point (1968) as I was only in the 5th grade.....
A couple years later, I discovered loud, fast Pontiacs. And then it took me a few years to save enough money to start buying them.
  #311
Old 11-29-2015, 10:08 PM
68RamII's Avatar
68RamII 68RamII is offline
I found a few more pictures of my car when I purchased it.
John R. Zerucha
1968 GTO RA II Convertible
Sorry..The race car is Buick Powered
70 Skylark @2800 lbs
8.78 @ 153 mph 535 Stage 4 2850 lbs
8.97 @ 149 mph 523 Stage 4
9.36 @ 143 mph 464 Stage 2
9.77 @ 135 mph 464 Stage 1
88 Hawk @2355 lbs
8.06 @ 167 mph 535 Stage 4
7.90 @ 171 mph 572 Stage 4
  #312
Old 11-29-2015, 10:09 PM
68RamII's Avatar
Another
John R. Zerucha
88 Hawk @2355 lbs
  #313
Old 11-30-2015, 06:15 PM
Are you able to identify any differences between those two blocks? (Besides the cast number...)
If the freeze plugs are removed, can you measure the cylinder wall or block thickness and see if one is thinner than the other? I am curious why the as cast 2506 blocks were discontinued mid way through the RAII production run. Comparing the two blocks you have may provide some clues.
  #314
Old 12-09-2015, 12:00 PM
NOPLNDN NOPLNDN is offline
Default Billing card update
Sorry for the wait.Almost a year....Here is a copy of my billing card.
  #315
Old 12-20-2015, 02:48 PM
BigJoel BigJoel is offline
Ram Air 2 heads on e-bay
http://www.ebay.com/itm/181967258588?
  #316
Old 12-20-2015, 05:40 PM
The Boss's Avatar
Split set, D228 & D238, very common from what I've seen.
  #317
Old 12-20-2015, 06:12 PM
Cool Kind of confirms the last date that was 'R A' only casting
And the date that started the 'R 96 A' castings.
Unless there is better documentation?
  #318
Old 12-20-2015, 06:15 PM
Thumbs up Here's another set, and he's got an NOS RH long-branch manifold, too!
http://www.ebay.com/itm/68-pontiac-F...ZWckpp&vxp=mtr
Somebody needs that manifold, don't they?
  #319
Old 07-12-2016, 06:54 PM
Default RA II GTO dash tach question
Does anyone know if RA II GTO's ordered with an in dash tach from the factory would have received a 5200 rpm tach or a 5500 rpm tach? Was a 5500 rpm dash tach available in 1968 with steel blue face?
  #320
Old 07-12-2016, 08:18 PM
The GTO that PHS sold at auction a few weeks ago had a tach in the instrument cluster. It was an 8k tach with redline at 5100 RPM.
I believe the redline on my RAII hood tach is the same (5100).
Sent from my XT1585 using Tapatalk
