#321
also, where are you getting the correct fuel pumps for these with the deep bowl?
#322
We arn’t
#323
the fuel lines arr the same material/size as other years;
fuel line routing differs, I can't say off hand right now if 1970's are unique; I believe I read somewhere that 1972-1977 are the same, but I suspect that was bunk, because the line I grabbed off a '77 L78 many years ago DID work on a 1972 engine, but required a long fuel filter housing to work... (I believe that 1975 was the first year of the longer housing) Fuel pumps... yeah, I realized a while ago they were a little tough to find, so I have bought them as I've come across them. Quite frankly, considering the number of applications that use them, I'm surprised the aftermarket hasn't stepped in with a correct looking pump that uses ethanol resistant rubbers. I have understood that they are pretty much a ticking time bomb (regaurding failing) when exposed to ethanol blended gasolines.
#324
70-71
#325
thanks, does it matter if the car had the evaporative system? wasn't that started in 71 or was it 72
#326
70 California car and 71 all others
#327
I found someone who did a short run of them, and had one left over! So I now have a correct air cleaner decal tucked away - Yay for me!! I will get around to making a new/comprehensive post; I started it last week(?), and just haven't finalized it. I'll get to it as soon as I have the time to sit down again, and continue typing/editing it.
#328
Are you sure the PN is correct?
So long, farewell. |
#329
#6486988
If you think about it, it isn't as much of an undertaking to run these off as it was, lets say ten or fifteen years ago, you just need a scan, some photoshop skills, and access to a vinyl shop.
#330
It is when they use the wrong PN, as I eluded to earlier. That is the same incorrect one muscle car air cleaners.com used on their refurbished unit.
#331
it's a little tough to make mine out from the glue residue;
#332
Jonny already has it on his list, but here's pictures of the glove box doors from a 1970 and a 1971.
The inner metal piece is a different stamping. ![]() 1970 has two similar sized sunken rectangles. ![]() 1971 and later have one larger raised rectangle area where the maintenance schedule label was placed and one smaller sunken area to the right for the tire pressure label. ![]() The 1970 also used just 4 rivets along the bottom edge where the 1971+ used 6 rivets. ![]() Yes, the hinge is busted. ![]() ![]() The plastic on the inner sides is also shaped slightly different. 1970 the plastic runs lower down the side and has a spare hole where a rivet could have gone. ![]() 1971+ stops shorter and the hole where the rivet could have gone is in the metal stamping but the plastic does not cover that area. ![]() The 1970 is in really excellent condition. Good hinge and color is still very good. ![]() I'm not going to use it so I should probably put it in the for sale section. Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 |
#333
this is pure gold!!
Thanks for sharing these pictures!!
#334
Jonny, how about the pulleys and brackets and their part numbers being added to the list.....
Sent from my iPhone using Tapatalk |
#335
Seeing Chads pictures reminds me of the brain teaser pictures we used to see as kids that challenged us to "Find all the differences in these two pictures!"
#336
So I would need some help there if this is to be done. I should be able to have time in the near future to start this again...
#337
Looks like 70 and 71 used the same KN label. I have a door that looks like the 71 style but has a KU label. Wonder how many years used the 71 style?
#338
3991751 8.800 All A,B,F ................ STICKER, vehicle safety maint 1 1971 1971 8-28 Looks like there was a change to the label during the 1971 year, too. Here's two examples of a newer style REV 1 KN label that were on these two Van Nuys cars. I wonder what the build date was on the second one? http://forums.maxperformanceinc.com/...18&postcount=2 http://forums.maxperformanceinc.com/...0&postcount=15 My KA labeled one must be newer yet since the hole where the rivet could have gone in my pictures above is not present on this one. Chad
#339
Ah ha! I knew it was in the AIM. It's in Section 10.
![]() KM is 1970 and 71 D/WS4, W66 KN is 1970 and 71 W/WS4, W66 Any other years should be in their respective manuals. KU and KA are not in this list so must be some other years. Chad
#340
Here's the same page from the 1970 AIM. The artists got it right between 1970 Firebird with the two equal sized depressions and the 1971. There is a KU in this list, but it's for a Tempest.
![]() Ric reminded me of the old "Find all the differences" so I looked more and another difference in the metal backing is the 1970 does not have the lower strip that goes underneath where the A/C vent would go, whereas the 1971 does and that's the area where the two extra rivets go. They must have had some reports of issues with that being a weak area or something. ![]() ![]() Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 Last edited by TA455HO; 11-28-2018 at 03:05 PM. |
