#3561
Note the clock Knob, That is a '70- earlier 71 item only..
the lighting, or it sure looks like black plastic??? |
#3562
edit repeat
#3563
The speedo is not a 70.......
![]() Last edited by Norwood; 08-07-2012 at 06:24 PM. |
#3564
![]() Quote:
It is one of the fluted black screw-on knobs which do have a different thread taper than the chrome knobs that used the center set screw. My December 1971 built 72 Formula had that black clock set knob. |
#3565
The knob could have been replaced since they do come off but you are correct in the fact a 73 would be chrome in appearance. Pretty cool car and hope if finds its way to a good home and owner.
#3566
Norwood, I sent you a PM for some stuff. Thanks
#3567
For archival purposes, and in case anyone missed it in the general 70-73 threads :
The Red 73 SD Test Car used in several magazine tests of the day has been found and documented. Turned up in Australia - with Right hand drive conversion. SD engine is gone. Car is still solid and otherwise held up pretty well overall for a car that had no special treatment and an unknown pedigree. It is a "Y" code car, btw Pretty interesting ordeal Link to that thread : http://forums.maxperformanceinc.com/...d.php?t=704249 |
#3568
Wow!
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#3569
Where and when??? Poor baby!
#3570
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#3571
Mike Pergande's SD........pre-1990 before it went on the ISCA show circuit.
Home of WFO Hyperformance Shaker induction. |
#3572
Thanks for the info Larry -
was about to ask if this was the TA that Country Singer Randy Travis just wrecked this past week . |
#3573
Yep,
I forgot about those pictures.....remember seeing them... Pergande had a red 73 SD auto too... I don't think that one was ever wrecked. Board member here owns the red car now, it is a real nice car. SDD
73 SD TA auto. 73 SD TA auto. 74 SD TA auto. 74 SD TA 4spd. 72 442 W-30 auto, post coupe Bamboo. 1 of 19 total. 90 300zx TT 5spd. |
#3574
So, the pics Lloyd posted are Pergande's SD?
#3575
Thats Right! Then it was restored to a number one show car but I have never seen those pictures.
#3576
Yep. Sitting forlornly in Gay Pontiac's (Dickinson, TX) body shop.
I can't recall if they repaired it and it later went to Sam Red for the resto and show paint, or if Sam did the entire job . . .
#3577
![]() Quote:
Considering how bad the Brewster car looked in those old pics, it sure turned out nice . . . Here are some "back in the day" shots of Mike's Buc Red car. Gotta dig those "Formula 1 Super Stock" tennies, and Mike's 'do as well! ![]()
#3578
Correct Lloyd, that car never got damaged and still retains its original sheet metal today. The engine bay was covered with WD40 or something which was a pain in the @ss to remove however it probably saved allot of corrosion in the long run.
The car rarely see the light of day now a days and its to bad since it is a pretty darn nice ride. ![]() |
#3579
Check the PERFECT stance in picture #3
#3580
Yessir - I absolutely agree, Craig!
