Old 03-20-2024, 07:37 AM
PLongen PLongen is offline
Default 63 Power Steering Pump Pulley Wanted
Looking for a 63 LeMans power steering pump pulley.
Specs for the pulley would be good too.
Than you,
Pat
Old 04-13-2024, 08:16 AM
Found pulley
thanks
Old 02-24-2024, 11:53 AM
tom s tom s is offline
FYI,the tempest PS is power assisted like early Mustangs and early Corvettes.Works pretty good.Tom
Old 02-24-2024, 03:11 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
63-67 Corvettes used similar slave cylinders, lines etc. The pump brackets you might to make?
Old 02-25-2024, 08:15 AM
I would like to get a picture of the brackets, there's a picture of the brackets in the manual but doesn't show the pulley side.
Old 02-25-2024, 08:38 PM
cleveweld's Avatar
cleveweld cleveweld is offline
I don't have a picture of the front bracket without the pulley in the way but you can see its general shape. Bracket is about 1/4" thick and has a jog to it. There is also a bracket to support back of pump. You need the correct ps pulley so it will line up with water pump pulley.
You would also need a PS center link, control valve, slave cylinder and hoses. A hole has to be made in fender well for the pump hoses to pass thru. Also need a bracket to mount slave cylinder to frame. A different pitman arm for ps also.
Your best bet is to find a junk 61-63 4-cyl. Tempest with power steering. There are rebuild kits readily available for the pump, control valve and slave cylinder as Corvettes used the same rebuild kits.
Name:	bike pics 017.jpg
ID:	629348   Click image for larger version
ID:	629347   Click image for larger version
ID:	629346   Click image for larger version
Name:	PS pump 004.jpg
ID:	629345   Click image for larger version
Name:	PS pump 007.jpg
Old 02-26-2024, 07:54 AM
thanks for the pictures that helps. All need now is a templet to make the front bracket. It shouldn't be to hard.
Pat
Old 03-26-2024, 03:50 PM
deanremix's Avatar
deanremix deanremix is offline
Still looking g for fenders and quarters for a 61 tempest if anyone has a bead on some lmk
Old 04-24-2024, 09:45 PM
They did make a 3.90 gear,had a set in my 63HO car I bought new in 63.I think pretty rare and takes a diff carrier as I remember.Dont know what uother gears were inbetween that required a dif carrier.Tom
Old 04-25-2024, 05:52 AM
Apsesia Apsesia is offline
I believe they also had something around a 3.55 and 3.78. Those 3 seem to all be harder to find. I’ve seen a bunch if 3.09.
Old 08-02-2025, 11:26 PM
Drag Star Le Mans's Avatar
Flexplate for 63 V8. My friend is in need of one and lives in Canada. The land of no 63 LeMans parts.
DragStarLeMans
Old 08-05-2025, 12:27 AM
ricks63 ricks63 is offline
Default 63 paarts
Hi i have lots of 63 Lemans Tempest parts, located in Thunder Bay Ontario. Contact me. Thanks
Old 08-06-2025, 02:35 AM
Stop looking, I dug deep into my stash and found one.
DragStarLeMans
Old 07-03-2026, 10:00 AM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
I am no 4 cylinder Pontiac expert, but I read your post and thought "If he can't find a Trophy 4 cam, why not use a V8 cam?" So then I Googled "can you use a Pontiac V8 camshaft in a Pontiac Tempest 4 cylinder engine?". The answer I got was ....
"Yes, you can use a standard Pontiac V8 camshaft in a 1961–1963 Pontiac Tempest 4-cylinder engine (the 194.5ci "Trophy 4"). Because Pontiac made the 4-cylinder by essentially cutting a 389 cubic-inch V8 in half, the cam dimensions match."
... but that was followed by ...
"However, there is a catch regarding engine rotation.
The 1961–1963 "Trophy 4" (Pushrod Engine)Compatibility: The camshafts for early V8s and the 4-cylinder share the same lobe spacing, base circle, and block-mounted design.
The Catch: Some early 4-cylinder Tempests used a unique "rope drive" flexible driveshaft that connected to a rear-mounted transaxle. These specific engines rotated backwards (counter-clockwise). If your 4-cylinder is a standard, front-mounted engine, a V8 cam will work. If your Tempest has the unique rear-mounted transaxle, a standard V8 cam will run your engine in reverse."
... REALLY? I thought ALL 4 cylinder Tempests used the flex driveshaft. And I've never heard that the half-a-V8 engine turned backwards.
Anyway, if the Trophy 4 does NOT rotate backwards and you can find specs for the cam you are looking for I'd bet that you could find a Pontiac V8 cam with similar specs.
My apologies if the Trophy 4 really does turn backwards.
Old 07-03-2026, 10:17 PM
1963cat 1963cat is offline
Bill, thanks for taking the time to respond the trophy 4 is indeed a half of a 389 but the problem arises due to the rod journals being 180 degrees apart and a v 8 s are 90 degrees so half the lobes will be in wrong spot. Yes the 61-63 tempest have a transaxle in the rear with a "rope drive" drive shaft which in reality a approximately a 5/8 steel shaft.
Old 07-04-2026, 09:18 AM
GaryK's Avatar
GaryK GaryK is offline
The timing on the Trophy 4 is different than the V8. If you want to use the V8 Cam, you have to use a V8 Crankshaft. It has been done. Not by me, but it was discussed on this forum many years ago. When it comes to the Trophy 4 and the transaxles, Google is not your friend, most suppliers don't know these cars that well either. I have been around these cars for over 45 years, I have had many arguments with people who say their parts will fit when they don't.
The main parts of the Trophy 4 that are different than the V8 are the Crankshaft, Camshaft, Distributor, Valley pan, Air Cleaner, Intake and Carb.
Search this forum for Charlie66, he has a turbo on his Trophy 4, he estimates around 800HP on his engine. There are others that getting a ton of HP out of these engines.
Old 07-04-2026, 03:51 PM
V8 cam blanks are available from a number of sources. Maybe that would be the way to go. Who cares if there are 8 uncut "lobes"?
Old 07-03-2026, 11:29 PM
I learned something today. Thanks.
So the crank is "flat", causing one compression cycle every 1/2 turn. With cyls 1 and 4 "paired" as far as coming to TDC at the same time and 2 and 3 "paired". Makes sense.
Old 07-04-2026, 07:37 AM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Bill let me check I should have a stock cam around here
Blown 4cyl's to the front
Old 07-04-2026, 03:53 PM
Rusty4cyl's Avatar
Hey Bill I have a 4cyl cam
