I went down a different path with gearing. Since my 360 will turn enough RPM's for a wide torque/HP curve; I left the stock rear gear (1974 4-speed), but changed to an ultra-wide ratio 4-speed.
Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
well okay if you be driving uphill most of the time.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Jon, you need to post a picture of your some day...
Best mileage I had with the LeMans, 461, 4L80E, 373s, 26" tire was measured on a 60mph average, rolling hills, about 500ft elevation was 23 MPG. That was done going to, and from a destination, both numbers were the same.
Like others, my issue with collecting MPG data was due to the right-foot variable. .
. 1970 GTO Judge Tribute Pro-Tour Project 535 IA2 http://forums.maxperformanceinc.com/...d.php?t=760624 1971 Trans Am 463, 315cfm E-head Sniper XFlow EFI, TKO600 extreme, 9", GW suspension, Baer brakes, pro tour car https://forums.maxperformanceinc.com...ght=procharger Theme Song: http://www.youtube.com/watch?v=7zKAS...ature=youtu.be Last edited by HWYSTR455; 09-04-2019 at 08:25 AM. |
Right after I put the TKO in, I got curious about mpg's. I posted this in a thread.....
"This morning I woke at my usual 5:30 and decided I'd take the GTO on a freeway run. I rolled into the Chevron at 6 and filled up --124.3 miles on the odo. I drove down to the Jack's drive through and got a sausage/egg biscuit for the trip. Back up past the Chevron I rolled up to 5000 rpm for a couple of friends outside the station sipping coffee. So much for fuel economy. About 3 miles to the freeway and off to Tuscaloosa, about 40 miles away. I run "about" 75 most of the way up and back. I saw 90 once. At 75 the tach is running about 2100+- rpm. The new OD is nice. At a steady freeway speed, windows up you can tell these 8 year old Radial T/A's are similar to Fred Flintstone's tires. Fairly hard and square. The drive train is smooth though and the trip is good. I roll back in to the same pump at Chevron and put in 5.064 gallons. I have been exactly 90 miles. --214.3 on the odometer. 17.77 mpg. 19mpg if I'd have tried? She did 13.20 @ 105.5 with a 2.10 60ft last time I went to the strip."
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
As requested:
Note that everything is green! Jon
Green is good.
It seems like most who check gas mileage on an old car make an effort to have optimum conditions and drive with economy in mind. I get that but I encourage more to drive the car like you normally would without mileage in mind. Burn some tire, let it idle, open it up a little, drive through city traffic, turn on your AC if you have it, etc. THEN check MPG's. To me that's the true MPG a car gets when it's used as intended.
Kind of like the EPA ratings where car companies tune and equip a car to get max mileage on the test loop then no one can duplicate it when they actually drive the thing everyday.
I seem to recall getting 14 or so driving an easy 50 mph on country back roads with my 505, 850 double pumper, wide ratio muncie and 3.54 gears with 28 inch tires. 65 GTO, about 3650 lbs full of gas without me in it.
Good enough for a weekend car, and not much different than my 6.0 2500HD daily driver. |
Jon, nice John Deere tractors next to the GTO!
I just finished a JD 730 and just about done with a model 60. The belong to my brother and I'm doing the engines, transmissions and 12v SI alternator conversions. Also converted the 730 from "pony" motor start to electric......Cliff
All the figures I posted above are driving in these conditions. If I were driving on flat ground and low elevation I wouldn't be surprised if those numbers picked up a bit. Our daily drivers I fill up weekly, I constantly check the mileage as just part of the deal. Force of habit and it tells me something is wrong if the numbers are way off. The Z consistently gets 15 mpg every week in around town traffic, stop and go, on 35-45 mph streets. My 70 Formula consistently gets around 14 mpg in those same conditions. Both cars jump to 17 mpg on the highway, before the Z had the overdrive. |
So the way I love driving it...15/16mpg cruising or less than 1 mpg at the dragstrip.
Thanks Jon!
I've heard you talk about it, here and there. I've never seen a green one, anyone else? The Pontiac Oakland event is in Tulsa next year (Early July) maybe you could drive it on down? Thanks again!!!
Is that correct, #76 primary jets, 517 cubic inches ?
My 505 has an RPM intake and an 850 double pumper. Still rich with 76 jets in the front. I think big street engines give a lot of signal and need small jets up front with a big PVCR.
As far as your other question; the car will not see another POCI event in my lifetime. No other comment on the subject. Jon.
