LG, your friend is all wet. Yes, you need to get it hooked up, but those 3.73's are totally wrong for such a mild 455.
Well im gona try the stickies this weekend and see what happens if it dont work out like i want i found a 3.23 disk brake rear end ill swap in.
Its kinda hard fer me to argue the fact on this matter with my friend when hes doing 8.70 et's on a naturally aspirated twin turbo Chebby, but like i told him I GOTS ME a Pontiac [img]tongue.gif[/img] , So maby this one time i can show him up with my wealth of knowledge that you guys have bestowed on me hehehe Thanks Mike Ps... hoping to prove him wrong hehehe |
Understood, but your friend is comparing apples with oranges. What works in a lightweight race car with a high revving engine doesn't always work in a heavy street car with a lower revving engine.
Well were going to see what happens this friday.
just installen new backing plate for my brakes, got my new rear sway bar connecting rod installed, and everything is a Go, lets just hope nothing else tears up gona load car on car dolly tonight heheMike Ps. ....I shure hope my friend is Wrong cuz i would love to get a set of highway gears in this thing lol |
L-Guy. You should definitly run better than you are. I run a 60 Ventura(4,300#) with a 400 motor and trans/3k converter with 3.64 gears and have ran 13.98/98.5mph with consistant 2.0 60' times.I use a 27.3" MT slick. I would imagine your car is lighter. I would start with the traction problem and try timing variations and check out fuel situation as others have suggested. I am no expert but if you are building for torque with a faily light car don't smoke it on the launch. Keep the gears reasonable. Good Luck. NO offense to your friend but you don't have a Chebby [img]smile.gif[/img]
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Well like i said i got the stickies on there now but they are only 26X10.50X15 so they 26" tall, found a set of 28X10.50X15's but dont think they will fit in my fender wells
im gona give it a run on Friday and see what the end result is. gona start the timing at 28 degrees total and work my way up from there. I know its not a fuel problem got a Brand new Holley Electric pump with guage and its putting out 7lbs on the money, and the volume is good. ill post tomorow night and let yall know what the times are...hope they alot better than before. i figure if it goes in the low to mid 13s then with a gear swap i should get into the 12s or at least i hope Mike |
