I have to agree that at this time a lot of Billet cranks coming out of Moldex are not cross-drilled.
We did some testing at Ford and found (like David R.) that cross-drilling the crank did more bad than good on high rpm engines and the oil hole did little on the low rpm engines. A better deal is to time (as was mentioned) the oil feed location so that the oil has built up a "layer" of sufficient thickness so that when the crank sees maximum loading the crank and the bearing material never touch. With a cross-drilled crank you have pulsing flow in the oil passage like a tuning pipe on an organ. This pulsing creates high and low oil pressure conditions at the bearing surface which would like see steady flow and pressure. A 3/4 grooved bearing with a conventional Moldex type oiling strategy is a better deal overall. I believe the cranks have duplicated some of that thinking. JMO Tom V.
Jeff Verdi 2016 Spring Fling Million Winner 2016 CARS Million Winner |
Robert C went back and edited his original post.
wade, anyone, any new info on time frame?
i could use a 3 1/4" main, 2.20" rod, 4.25" arm. someone else have a used billet piece?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
4.5" - is that for tow vehicle applications?
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
Wow this is great news. Now I will be able to build a big power turbo motor at a much more reasonable cost. A big Thanks to those involved.
Wade or Bob C.
Will there be a possibility of a 3.75" stroke with the 4" main? A minumum order perhaps or is it just not possible? |
If at anytime you'all feel the need to know just ask or call.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 [email protected] Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
The Moldex crank I just sent to Tom McQueen had the Moldex oiling system (same as Bob C. mentioned for the forged cranks) with the oil scoops. Not Cross-drilled.
Tom V.
I would also like to know about a 3.75” arm, there was talk about these in earlier plans. Has this changed?
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
I think there will be more demand for the 3" main cranks than you might think. Many of us would like to use these cranks in 400 blocks as the 455 blocks are getting pretty rare. There are still a lot of folks who will be building motors using OEM 400 blocks. So you might consider making some 3" main cranks with 4.21, 4.0, 3.75 strokes. Lots of people are having problems with the aftermarket cast cranks, even in mild HP applications. All of us don't have the play money budget that includes after market blocks. I think that overall, the OEM cast 455 cranks are holding up much better than the after market cranks are.
Tim C
Tim Corcoran |
Count me in,I will have my deposit in as soon as the OK is given.But do you guys think that it is worth it to run one in a factory block since the safe horespower limits seem to be about the same for both cast cranks and OE blocks(700-750HP).Since Whittmore is taking his sweet a$$ time with my 4.25 stroke 400 block combo it has got me thinking.I mean it would not run any faster but would the reliability factor be of use since I do not plan on making more than 650 HP for the near future.
AllPontiac/BOP are planning on having 3'' and 3 1/4 main cranks. Strokes will be 4.00, 4.250 and 4.500. on the 3'' main. We do not know the stroke on the 3 1/4 crank at this time. But there will be one for that size for sure.
Yes, there are a lot of motors running the flexObend brand cranks. Some will last and some will not. You can't make power and trust this type of crank anymore.
The sizes are as Bob has stated and there is no plan for a 3.750 at this time. The 3.25 inch crank looks like it will be possible, but probably only in a 4.250 stroke.
Wade Congdon BOP Engineering Hi-Performance Specialty Parts for Buick, Olds, and Pontiac www.bopengineering.com |
Woo Hoo, all right
Can you also machine these forgings for an Oldsmobile ? We can use the 4.25" and 4.50" strokes easily. (a 4.5" stroke and a 7.3" rod )
Tim King |
Call me on this. 804-349-0014 cell
#38
"a 4340 non-twist forging" -wow, non-twist, somebody likes this project.
Since crank fractures happen at the journal radiussess BEFORE ever happening at the oil-drillholes, I ask aboout Radiusing: Traditional old PMD radius cut, or the new-ffangled undercut technique? Also, what is the optimized Main Bearing set for the new crank: upper half-groove, 3/4groove, full-groove?, no groove=grooved crank, funky groovey. HIS
#39
Will do Bob ! Thanks !
Tim King |
#40
the factory cast cranks tend to develop cracks in the rod fillets after 2-3 years racing, making only 650 HP- and the factory cast cranks were actually VERY GOOD, being nodular iron- they had magnesium added to the mix to change the grain structure from flake to sphere shape if/when these forged cranks become available, we can then throw away all the Chinese cast cranks where they belong- in the heap pile |
