You Know what #, I may have to go to 2" with my 535. Is it #4201# John
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 Last edited by JKrull66; 02-10-2007 at 06:22 PM. |
So has anyone else had any luck with these 4201 SC headers?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
I am pretty sure that is what is on my car. You have to "massage" the passenger side frame rail and grind one little spot on the back of the engine crossmember, other than that they actually fit pretty well.
I will check and see if those are the ones I used. Kip
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. 1966 GTO Hardtop - PS 14.84 @ 97mph |
Did Apache Warrior ever get the car to the track?
69 Judge RAIII 4SP 2ND OWNER 63 Catalina 421HO 4sp 66 GTO Conv 4sp 73 Trans Am 455 4sp http://www.sdperformance.com/ Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds. |
is the car tubbed? i dont want to tub mine, if not tubbed, what size is the rear? drum to drum, what size tires wheel back spacing.
1971 ventura 455 12.04 @ 110 w/ crummy 1.69 60 ft - so far! NHRA super gas licence holder 9.31@145 @ frank hawleys in a 2000 firebird |
I put the car up on jack stands and dropped the rear transaxle out of the car. the first thing I bought was the rims and tires that I wanted to use. I set them under the car in position and then measured the distance between the rims. I gave that dimension to the guys building my rear-end and the rest is history. Everything lined up great when everything came together during assembly. Kip
If you want a 9" the Ford 77-81 Granada/Versailles is 58" and from what I've heard here it's pretty close to perfect. Again, it all depends on the wheel width and offset used too. I have a 28"x12.50" Mickey Thompson ET Street on a 15"x8" Mickey Thompson ET Drag wheel under mine and it's pretty close, but it fits.
This is the way to do it
Agreed! It is so simple and effective, it's almost like cheating!
This might be a very old thread, but a good one! |
I did like spartazoo. Got 275/50/15s under the 63. Put the tires and wheels under the car with your ride height and do the measuring. Don't forget the thickness of the brake drums also. Ford 9 inch aren't on center so if getting axles made there's two different lenghts. I didn't relize when having axles made you can specify wheel hole pattern. I got tempest front ford back and one spare which only fits the front. Didn't make this mistake when doing the 61 wagon.
I had my axles made with 4.5 x 5 bolt pattern to match the front. I also have an extra pair of 15x8 plain steel wheels that the company I ordered from made by mistake. They are just begging for installation on a 63 Catalina SD clone...Born Too Late II? Hummm
Spartazoo:
My '63 Tempest has 4.5 X 5 up front and 5 X 5 big Pontiac in the rear. However, the 9.5 inch dog dish caps I want to use won't fit on any 5 X 5 wheels. Only 10 1/8 caps fit. Where can I get my axles converted to 4.5 or buy new axles with 4.5 wheel bolt pattern? BTW, the wheels you had made. They are 4.5 X 5 on 15 X 8? What is the backspace? I may be interested. Last edited by grparen; 05-06-2010 at 02:38 PM. |
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
...... so what is the latest on this car ?? ........
