Old 12-22-2006, 06:55 PM
60 Foot E.T.: -- 1.25
1/8 Mile E.T.: -- 5.68
1/8 Mile Trap Speed: -- 119.66
1/4 Mile E.T.: -- 9.00
1/4 Mile Trap Speed: -- 156
1/4 Mile Trap RPM: -- 8,560 RPM
Old 12-22-2006, 06:46 PM
John Langer's Avatar
John Langer John Langer is offline
So what does your calculator say if a motor makes 976 hp and weighs 3250?
Old 12-22-2006, 07:01 PM
Motor Daddy Motor Daddy is offline
The same as 3.3299 lbs at 1 HP, [email protected]
Old 12-22-2006, 07:08 PM
Aint no way in hell a 1000hp N/A car is going to pick up 36 on the back half weighing 3250. 29-31 is average. My pass was 1.22 60', 5.46 at 125 at the 1/8 and 8.61 in the 1/4. The car went thru the lights at 8800rpm.
Old 12-22-2006, 07:21 PM
TH400 or Powerglide?
4.88 rear gear?
Old 12-22-2006, 07:27 PM
aint no way in hell anything other than an inefficient power adder car is picking up 36 on the back half
Old 12-22-2006, 07:35 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
These Calculators just bring it out in the open how much our air sucks here. To correct a 650 HP motor in the West Texas summer plan on subtracting 109 HP
LOL
John Krull
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 12-22-2006, 07:53 PM
What's 36? MPH?
My dragster is the opposite of what you and the other high HP guys run.
I usually have a great ET but a poor MPH.
I usually run 8.20's in 1/4 with only 153 mph.
These equations aren't accurate but they usually get you in the ballpark.
If you want accuracy, I would try PipeMax from maxracesoftware.com
But for free . . .
Old 12-22-2006, 08:55 PM
Jeff V Jeff V is offline
Smile My Results from Wallace Calculator
482 cubic inch in Firebird
Your HP is 725.84 computed from your vehicle weight of 3060 pounds and ET of 9.41 seconds.
Your Horsepower computed from your vehicle weight of 3060 pounds and MPH of 143.5 is 743.18.
474 cubic inch in Firebird
Your Horsepower computed from your vehicle weight of 3060 pounds and MPH of 141 is 705.01.
Your HP is 705.40 computed from your vehicle weight of 3060 pounds and ET of 9.50 seconds.
500+ cubic inch in Firebird
Your ET / MPH computed from your vehicle weight of 3000 pounds and HP of 800 is 9.05 seconds and MPH of 148.05 MPH.
This calculator is pretty darn close.
My new engine combo for 2007 will be a 500+ cubic inch that should make about 75-100 more hp than my 482.If this calculator is right,I will be one happy camper
Jeff Verdi
2016 Spring Fling Million Winner
2016 CARS Million Winner
Old 12-23-2006, 01:15 PM
Old Goat Racer's Avatar
So what causes the difference in horsepower ratings between ET & MPH formulas ? Which one is accurate or do you average the two?
Old 12-23-2006, 03:45 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
John,you know I've gotten blasted by some here as making excuses when I mention "conservative dyno numbers" that match the Moroso slide.
Here's the 525hp engine dynoed 455 in a 3750 lb TA with a street convertor
60 ft 1.616
1/8 7.04 @ 99.1
1/4 10.995 @ 124.5
Old 12-23-2006, 05:26 PM
old goat racer, the MPH equation is probably more accurate.
ET can be affected by many things.
But the MPH is usually the same if it's ran all the way through.
For an excellent ET calculator, try ET Analyst
It uses more inputs and is relativily cheap.
Old 12-24-2006, 12:10 PM
Thanks John. Using the MPH I come up with 455HP, & using the ET I have 473 HP. That will give me a number to throw at racers.
Old 12-24-2006, 01:25 PM
XSIVPWR's Avatar
XSIVPWR XSIVPWR is offline
When I calculated mine the ET & MPH were 2hp apart.
Old 12-24-2006, 02:14 PM
Half-Inch Stud's Avatar
...temperature changed during calcs
Old 12-24-2006, 05:53 PM
XSIVPWR's Avatar
Oh-k
