The classes we run prevent us from being able to use a 4-link. A 4 link does have several advantages over ladder bars, you can compensate for a bad or really good track as well as hooking with out having to carry the front end as much. That said one of our cars 60s in the 1.17 range with the back tires on a 29.5 10.5 slick with ladder bars. Wheelie bar adjustments and wheel speed become very critical on this car. FWIW
Had a 1.37 in my stock suspended GTO............. In my opinion, unless you're looking to get into the 9's or faster, leave the stock suspension in it. If not, go with a 4 link. |
I never want wheelie bars, so maybe a 4link would be better since I can control wheelies with a 4 link. I know that John Langer has a ladder bar car and his doesn't wheelie much. I'll never make power like that. Is there a way to fine tune a ladder bar car so you don't pull the front up as much? |
Yep.
But you have to be able to move weight around the car and adjust the front suspension. |
Before back halving it have you looked at the Slider Link bars? Once you hack the back, and tub it, you'll probably have to narrow the rear seat.
If anything you could go with a mini-tub, deeper offset wheels, slider links and keep the back half as is. Just a thought. I've had Slappers, ladders and 4 links with wishbone on various cars. And now slider links on my 68 Bird. Haven't tested the sliders yet but they seem to offer adjustability and preload without sacrificing ride quality. 4 link was the best on the strip. Ladders worked well on the street and strip but the ride was harsh. |
I'lll see if my buddy will get a picture of his bent slider links. His camaro makes 650 hp in it's current low compression state with the 615.
What kind of buckets?
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Do you know if the rear seat fits the ventura's? Is it the same material? I assume the fronts fold ahead for rear seat access. Pretty comfy? Might be what i am looking for.
The seats were done by a local upholstry guy that does most of the hotrods in my town. He's been doing it for 30+ years. I did my homework on all the shops in town and he was the best. yes the fronts fold and move foward. Comfy, yes, all new foam. I don't know if the rear will fit in your car. Good question. |
461 400 block. IA prepped 300cfm E-heads .660-.680 solid roller. Wilson ported intake. Modded for EFI by Steve Grebeck. Eagle stroker kit. CP pistons. TH400 ATI 4400 stall converter. 12 bolt with 4.10's and Detroit locker. 29.5x10.5W Et Drag's dollar motor |
LOL. That's a million dollar motor?
You must not know much about motors......... |
My old 71 ventura went 9.11 with a 1.33 60ft all steel with a ladder bar and 29.5-10.5w.With my new motor went 8.68 1.33 60ft on 29.5-10.5 non w.There is also a nova in my class that has gone 8.20s with cal tracs and radials.
not sure of the owners name but i think he is from the chicago area.
#38
#39
Not the same car but it looks pretty sweet.
#40
That nova just went 7.80's on a 275/60 tire with caltracs.
