Old 09-23-2009, 12:11 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Default It fixes everything!!
I tried to fix this glass candle holder for my wife. The Cat knocked it over. I tried averything, then she said I can tie something over it. I thought JB??? It worked great! Sanded easy and can be molded like bondo!! pics arent that great, flash is on glass after all.
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 09-23-2009, 01:09 PM
Overkillphil's Avatar
General use
Qjet wells:
Old 09-23-2009, 09:04 PM
stimpy stimpy is offline
can't fix the economy with it ....
Old 09-24-2009, 06:27 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I see LOTS of q-jets that have had JB Weld dabbed over the bottom plugs. It doesn't work well for this purpose. The fuel will "soften" the glue and lots of heating/cooling cycles will cause it to come loose.
Just yesterday I pressure tested one that looked like it was still holding fine, and it leaked right thru the JB Weld on one side. That particular repair didn't look that old, but I've learned to remove the JB weld, pull the plugs, thread the castings and use screw in plugs coated with Marine Tex instead....Cliff
Old 09-29-2009, 04:06 PM
Judas Judas is offline
I've used it to successfully patch the leaking radiator in my 79 Camaro in '92 or '93. It was leaking where the upper hose connection meets the tank. I was bucks down and desperate. The fix lasted a full year till the radiator started leaking again from pin holes in the tank but by then I was better off and bought a new radiator. Definitely sold me on the product.
I noticed by other replies it seems to do well on radiators- it must like brass.
Recently (last summer) I used it to glue a small hose connector back on that was cast into the side-cover of a 92 EX500 (baby Ninja). The connector had broken off very cleanly so I figured "Why not? its only a few bucks to try...". No problems. This was another "cooling system fix".
Also I tried to use it to patch a large "burst" at a muffler seam on the Camaro. That fix...not so successful.
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
Old 09-29-2009, 04:13 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
The only thing JB won't fix is the crack of dawn and maybe a broken heart! Great stuff! -Jim
Old 09-30-2009, 08:09 PM
Shiny Shiny is offline
I like the stuff, but must admit it let me down bigtime when I used it on my timing cover where there was a hole between the water side and oil side. I had prepped it well, and it just lost adhesion to the casting after being heated and cooled by the antifreeze a few cycles. It didn't dissolve or anything, but stopped sticking. I wish I had thought more about the consequences of it failing before I chose to use it there.
Old 10-01-2009, 09:04 AM
mviker's Avatar
mviker mviker is offline
It fixed a pinhole leak I had in a power steering pump. Worked like a charm.
Old 10-01-2009, 09:59 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
JB Weld has worked great for me in all applications EXCEPT putting studs back on some 66 GTO tail light bezels.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 10-01-2009, 09:59 PM
lowrider lowrider is offline
Default JB weld
will it work on enduro bumpers. I have about a 1/4" chunk out of mine I need to fill with something
Old 10-01-2009, 10:39 PM
No, you definitely want to use a flexible filler to repair an Endura bumper.
Old 10-03-2009, 09:26 AM
I've got two.
1. It can't fix a cracked exhaust manifold heat riser. Not for long anyhow. I guess the extreme heat softens it. I tried it on my '69 LeSabre two or three times. It would repair the leak every time but would only last about 20 minutes into the first run.
Possibly I didn't get it quite clean enough by wire brushing but I just don't think it can stand the heat inside the manifold..
2. I once made a muffler out of thin aluminum for a 2 cycle model airplane engine. I glued it all together with JB Weld. That lasted about five minutes before it blew apart. High frequency vibration was probably the culprit there though...plus, very little mating surface for the parts that were assembled.
I did modify a factory muffler later for another similar engine and in that case it worked fine. Didn't crack until I crashed the plane sometime down the road...
Old 10-03-2009, 11:22 AM
1971GTO's Avatar
1971GTO 1971GTO is offline
I used it to re-furbish the rusted metal at the lower corners of the dash-windshield before I installed the glass. Good stuff.
1971 GTO: Quezal Gold, non-R/A 455HO, TH400, 3.55 Safe-T-Track, 1 of 412.
turns in 13.4@101 miles per, "Hey these 'ol GTO's haul ass"!
Old 10-03-2009, 07:18 PM
RA6T7GTO's Avatar
RA6T7GTO RA6T7GTO is offline
Send a message via AIM to RA6T7GTO
i used jb weld on my 78 suzuki engine case when i put a hole in it while installing the gear shifter on, i had it a few years and never leaked
1967 RAM AIR GTO 1 OF 156 AUTOMATICS
Old 10-03-2009, 08:15 PM
301Store 301Store is offline
Originally Posted by Tone View Post
So the question is...is there anything it can't do?
Yes, it can't fix a radiator that you would ever want to have rebuilt one day.
I did this once, then a couple years later I went to have the rad recored.
The tank I used the JB on had to be replaced instead of repaired. Apparently once JB weld is on there, the rad shop can't get it off well enough to have clean metal to solder for the repair.
Fuel tanks, be careful. The patch softened up on me after a couple years and started dripping. Worked well enough for a while though.
Shawn
Old 10-09-2009, 11:34 AM
Stuckinda60s Stuckinda60s is offline
I didn't use JB, but used Plastic Steel for a similar repair. I cleaned it really well and ran a brass screw through the pinhole through the casing. I still have the cover and it's still tight after 40-50 thousand street miles. The repair didn't separate from the casing, at all.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 10-09-2009, 12:23 PM
I wish I would have asked for help first !! My luck has been running that way lately. I'm glad to hear yours worked. I suspect putting a screw through it was a very smart call, and perhaps the adhesive you used is more resistant.
The pics attached show my failed repair. When I did the repair, the JB Weld was hard and well-bonded, as I was able to grind it flush with the casting surface with no hint of bad adhesion. You can see I did a decent job prepping the holes with a dremel burr, and the JB Weld did not disintegrate, but simply popped out of the casting. A screw through those holes probably would have trapped the epoxy and kept it from leaking (like yours), but I think the loss of adhesion is an unavoidable chemical reaction when exposed to hot antifreeze. It would be interesting to know if there are other adhesives that would hold up better in the same situation.
The white glop dribbling out of the failed repair site is what my oil looked like after being mixed with a couple gallons of coolant. The nuggets are the JB weld plugs that popped out and were laying inside the cavity when I pulled the water pump off.
Name:	Bad Judgement 011_640x480.jpg
ID:	183723   Click image for larger version
Name:	Bad Judgement 009_640x480.jpg
  #38
Old 10-09-2009, 02:58 PM
Yours was much further deteriorated than mine was. For yours I would have prepped both sides, roughing the surface to get adhesion, smeared the JB-Weld on both sides, making sure it was pressed in from both sides. Then using a piece of roughed, light sheet aluminum on both sides as a strongback, pressed as closely to the cover surface as possible, with a minimum amount of epoxy between the cover and the metal. The excess epoxy can be used to cover the metal.
What you end up with is a sandwich with the cover and epoxy in the center, a thin coat of epoxy on both sides (as bonding agent), the sheet metal on both sides and then another layer of epoxy. You end up with the epoxy as one piece from the hole, under the metal and then around it over the sheet. The sheet may erode to some extent if it's exposed, but will still give strength to maintain the patch.
Doing it like that gives the epoxy some support so that it doesn't have the pressure pushing against a broad area trying to separate it from the cover.
The problem is caused by allowing the anti-freeze to get acid. When it does there's electrolysis between the aluminum and the cast-iron of the block, wasting the aluminum.
If you take a voltmeter, stick one probe into the anti-freeze and the other on the block, you can read a voltage. You should read less than 0.4 volts if the fluid is good.
Rich
Henry Ward Beecher
  #39
Old 10-09-2009, 03:50 PM
Bjorn's Avatar
Bjorn Bjorn is offline
well, I know one broken thing it cant fix....
a broken heart!
FireBjorn
http://FirstGenFirebird.org/show/closeup.mv?CarID=221
breathe and enjoy it , life is temporary
69 Firebird convertible
71 Triumph TR6
  #40
Old 10-09-2009, 07:11 PM
guccieng's Avatar
guccieng guccieng is offline
Is there anything JB weld can't do? Seriously.
it can even revive a 2 year old thread! (sorry, guys. i couldn't resist)
John J.
