Made in China.
Need I say more? We gave them the one thing we were good at, quality manufacturing, and they're F'ing it up.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
We spoke on this five pages ago, and this is what I said back then~~>
#44 10-20-2008, 02:24 PM SLICK1 Senior Chief Join Date: Nov 2005 Posts: 429 Exactly the same situation we had on my Buddies SBC Malibu, we had to send it back and demanded his money back! Put a stock balancer on in the mean time so he could get the timing right and go racing! Sorry to say these should be avoided at all cost, and I don't like slammin products but this obviously can ruin someones motor, time, & hard earned cash because of a poorly designed product! __________________ (here is the link to the topic) http://forums.maxperformanceinc.com/...d.php?t=577458 |
did u get your money back?
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
ATI for me.
I like saving money as much as the next guy but some thing you cant go cheap on. Pro products looks like most all their stuff is crap.
Am I missing something? Please correct me if I'm wrong, or suggestions for a quality balancer? Are the newer $50 GM ones any good since they discontinued the old P/N 477681 $125 piece? BHJ?? Help!
"XE cam basher" Last edited by 67 Lamnas; 10-30-2008 at 11:11 PM. Reason: omitted words |
Buy the ATI and be done with it. I've had mine on the car for around 8 years. Never a problem. You don't hear of problems with ATI balancers. Use a BBC pulley and you are in business. If you go drilling the stock pulleys to fit they tend to crack and come apart. There are juist some things you don't want to cheap out on, the balancer being one of them. |
Summit SFI Pro/Race Not to be Confused with PP POS, 230$ Very nice piece 4-bolt Bolt On No Mods, Splined hub and Ring, Very Nice Piece, Butler used one on their 467 EMC engine as well, FWIW
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
One the ATI there is like 5 different models wit 2 or 3 rings and steel or Alum Shell, Which model are most of you using?
All they would do was send a replacement...I just recieved it today. It has a 1 year warranty. Does anyone want to buy a NEW balancer??? It is in a new box and has the SFI sticker....come on anybody...
If the outer ring is rotating and the timing mark is off, apparently its easy enough to fix. From the second paragraph of Pro Products install sheet (complete pdf below)
"We suggest you line up the TDC mark of the damper with the timing tab before removal. After installing new damper, if marks don't line up, you will need to get an aftermarket bolt-on timing tab or possibly make a custom one for your application." So if the PP damper is not indexed correctly just move the timing tab and all will be well ? WTF!!! |
i have a new pp balancer on the shelf too, got it from sdperf. now iam thinking i should have put it on the " junk from the garge" list of things to put on ebay a few weeks ago. at least it was only 60 bucks
I bought a fluid damper here is the part # on summit 650401 I've had this thing on my motor for 2 years with rpms @ 6600 with no problems.It pays to spend the money.
SFI means it has to be good.
![]() I would run a stock Pontiac before that POS. Take an ATI balancer apart. They are awesome.
Tempest455 |
Oh Sh!t!! I put one of those on my Dad's engine. When I was timing the distributor, the TDC mark wasn't even close, had to put a tape on timing mark!! Now what do I do?
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
I would get it off there asap Bill!!
i run stock dampers..thats what the cranktrain calls for..spun big rpms many times, no failures of cranks or hubs..sfi is just another ploy to take your money and control you...screw sfi in my book..
if aftermarket assembly, buy the best you can find..crank vibes hurt |
Skip do u have a address? I would be willing to do so or atleast call them!
I "dunno" what brand Balancer I gots. all I know is my SFI balancer was made in Australia, and that it either may have been a 1-off "production run" or they raised their price after the production run. Far as I know it is still a superb balancer, that I cannot get again.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
About a month ago i had a problem with a factory balancer it finally gave out broke from the key way. i purchased one of the pp balancers from ace brewer in california. i raced my car this past weekend we ran a best of 11.20 at 120 mph. My motor does not see anything over six grand i am a little nervous reference the balancer but i did call ace when all the contraversy involving the pp balancer came up. He did give me good news and if i have a problem he told me he would make it good. Ace if u are listening please state ur two cents. I am sure i am not the only one on this boat. Later.
Punisher#1 has had two BHJ's spin the inertia ring. Pontiac Dude also had the same issue with his as well.
