To one side of the valve stem you will observe a stamp that will appear like "M19" with the "9" below the "1". The "9" indicates the year 1969, a "0" would be 1970, etc. Between this stamp and the valve stem will be another number from "1" to "12" which will designate the month. On the other side of the valve stem will be a number between "1" and "31" designating the day, and beside that will be the wheel code "KR" or whatever code the wheel actually is. Quote:
That is correct. It's a 14" center mated to a 15" rim. Not sure if all KRs up through 1973 did look the same, but I believe so.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 |
All JW, KN, KR wheels looks the same. AFAIK, the last batch of KRs looked to be in spring '72 (it may have been the 2/72 date, not sure). For the '73 model year they developed a 15" center for the 15" rallys and the code again changed, to HM I believe.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
KR's stamped 3/25/72 are the latest stamped KR's I've ever ran across & have been buying/sellng/trading for JW-KN-KRs for the last two decades. Have one 3/25/72 that has a GM parts distribution sticker on it its spine... sold over the counter as a service part. Have owned NOS JA's, JL's, & HM's with same sticker
My '72 T/A, built during last full week of '72 production (3/31/72), has 2/28/72 KR's on it. While the whole set is not original to the car (only 2 are), managed to come up with 5 that date matched the original two. '71455HO, On a 09A built '71 Norwood car, 7/27 or 7/28 KN's would be correct. Other than 7/27 & 7/28's I've only owned one other date of KNs, they were stamped in August of '70. Believe Aug 13, but would need to dig in my old records. The Fall of '70 UAW strike began Sept 14, 1970 & lasted 67 days. This strike shut down every GM asm plant & production of GM specific parts at its suppliers. As a result, the strike had a profound effect on the dating of parts used on late Nov, Dec, Jan, & even Feb assembled cars. It's interesting that over the last few years, parts have emerged that are dated slightly before the strike was settled. The 11/10/70 dated KR's & a pair of Canadian mfg 14x6 KU's (Paul K) I've examined, both point to rally wheels being stamped a good week before production resumed. BTW, not going to see this early startup with internal produced parts like blocks, heads, manifolds, waterpumps from GM Central Foundry. As far as Van Nuys cars go, its become evident that Van Nuys still had a decent supply of JW's & used them well into the late winter of '70-71. Would be interesting to know how many '71 Van Nuys Formulas & T/A were built with 15" Rally wheels over honeycombs??? I bet the number is not that big with Norwood producing much higher amount of '71 T/A's & Formula's. Have owned quite a few 12/29/70 & 12/30/70 KR's. Get a chance, will ck my warehouse for dates of JW's & KR's I have. Last edited by 'ol Pinion head; 01-07-2009 at 03:39 PM. |
Are KN's the only correct wheel for a 0 9A built Norwood car. Aug. 13th 1970 is also when my Intake was cast incidentally.
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
All the original intact early '71 Norwood cars, I've personally examined have had KN's. There may exist an extremely early production '71 Norwood car which had JW's, but have yet to document one. If the project was mine & it was destined to be a cutting edge concours resto, I'd search out a set of 7/27 or 7/28 KN's & an nos set of trim rings. Short of that level of resto, repro trim rings hide the stamped dates fairly well.
BTW, my '71 HO T-37 has the 8/13/70 intake & 483637 casting block. The T was built late Dec of '70. |
Trim rings? I thought T/A's didn't use them.
Aut viam inveniam aut faciam 1971 Trans Am 455HO M22; Cameo White / Blue 1971 GTO Convertible 455 M40; Starlight Black / Black |
Optional. But not many had them...
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
My car has the 483637 block also, and I do have an NOS set of trim rings in their boxes. But I prefer the wheels without the rings. Now...I only need another $100K for the concours resto. Ha, that ain't gonna happen. Anyway, I want to drive mine. I am doing the best I can though. I hope to get it back this year.
Here's MY contribution....... (obviously NOT in chronological order)
JW... 7-15, 9-4, 6-25, 1-27, 1-26, 4-27, 4-13, 5-11, 1-26, 3-9, 4-6. KN... 7-28, 7-27. KR... 12-30, 3-25, 5-29, 12,29, 7-21. One of the KR 12-29's still had the GM part# tag on it,so it was sold as a service replacement part. |
In addition to those, I've got/had JW 4-10, 5-25, & KR 11-9.
JW's: Mon-01/26/70, Thu-06/25/70, Wed-07/15/70, Sat-07/25/70, Fri-09/04/70 KN's: Mon-07/27/70, Tue-07/28/70, ?Thu-08/13/70? (maybe) KR's: Tue-07/28/70, Mon-12/28/70, Tue-12/29/70, Wed-12/30/70 Mon-01/04/71, Wed-07/21/71, Wed12/08/71 Mon-02/28/72, Sat-03/25/72 I saw that a couple of these hit on a Saturday, Do you think that maybe the plants worked overtime occasionally to catch up, or is it just a mistake some of us made?
Note: I made a mistake on known date codes for 1971 KR wheels. Wed-07/21/71 wheel date code should have read Thu-01/21/71 (happens to be two of my four wheels).
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 Last edited by 1971455HO; 01-17-2009 at 03:59 PM. |
Thought I would bump this up again. I remember talking to Ole 'pinion Head and finding out I needed a set of 7/27 or 7/28 KN's for my car. My car was built one week before the big strike. If anybody has what I need, I have five KR's to trade with.
Eddie - What are the date codes on your KRs? Any interest in trading one KR for one KN? You can PM me if you want to discuss.
Chad |
I have a set of restored 7-28 Kn I would sell for 1200. Dont need any Kr's. Pm me if interested
1971455HO,...so your TA is an 09A build? Are you sure it should have KN's? Some very early '71's had JW's. Even some I've docemented well after the strike, had a mix of JW & KN. I'm betting your Build Sheet would show JW also.
Ric - 1971455HO has a Norwood car so likely no build sheet unless he got real lucky. Didn't all build sheets call out JW if it was a Rally II wheel? Or have you seen examples where it lists KN or KR?
Chad |
#39
No... honestly, I'm not sure. I was just reading over some old post here and one of the members here who I'm sure knows more than I do said "all of the intact early 71 TA's that he has documented had KN's from the factory on them. That's why I thought I needed them. As to my build sheet, I hate to even think about it. I got this car in 1980. Traded a 5 window cab '50 Chevy swb P/U & $1000,00 for it off of a car lot. First thing I did was come home and start cleaning. I removed the bottom back seats and discovered some folded up papers under the seat springs. Looked them over and said to myself, "This is from when they built it at the factory, I don't need this crap"!...in my ignorance as I cleaned it up,I let the vacuum take care of them. 7 yrs later I learned what I had done. Been crying ever since. Anyway, I'm not sure what wheels are supposed to be on my car. I got a set of Honeycombs, a set of KR's and I'm talking to a guy about a set of KN's.
#40
Eddie - Do you have the PHS docs for your car? I think it would say if they were Honeycombs originally because of the extra charge. Not sure if it says anything about Rally IIs if you got them instead, but I think it is a clue.
