| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Here are a few pics of some wild force fed machines...
Our GTO best et 7.80@175mph at 3350lbs 60' 1.17 on m/t et street tires with a light tune up of 20% over driven. no it's not poncho power it was a 540 bbc sorry chebby lol.
![]() ![]() Ron
Here's one from "Po Boy Racing"! LOL Darn near stock bottom end real Pontiac 400 too!
Engine combo in Signiture W/ an ICE brand plate style kit. I bought the kit used for $100 3-5 years ago. IIRC The date on the bottle is maybe 1985? lol I'm still working out the jetting stagger, but it does work. Hoping to widdle the ET/MPH down to 10.99 by the end of Summer. Building a new stronger engine for next season may.may not use the nitrous on it. JD ***Add 100 shot to 3.70 setup: Calc. DA 2028' 11.66 @116.33 1.71 60'
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
535 ia 2
4.5 stroke all pontiac crank 6.8 eagle rods ross pistons out of the box 365 version high port heads victor intake with a single steve johnson fogger 1150 holley 2 inch mad dog headers with magnaflow 3.5 inch mufflers th400 4.29 gears On a 38 jet with a 30 fuel and 5 lbs flowing with 12 degrees total timing the car went 5.35 at 132 so far. Crappy 1.29 60 foot. I am confident the car will run 5.2s with this tune up. The car is also 3525 lbs at race weight.
www.MidwestStreetCars.com Butler Performance Quillen Motorsports Don Dial Race Cars |
best pass so far . 9.89 @ 137 mph 1.41 60 ft. 4220 race weight
67 lemans 535 ia2 with a homebuilt 91mm turbo blow thru setup
-Rob 67 LE MANS in pieces... 68 gto 84 grand prix twin turbo 496 pontiac 25.3 cage |
1967 GTO .040 455 6x's mild hydraulic roller 3000 stall 3.73 gears. 3560lb with me in it. 12.14@115mph on the motor 11.45@125mph on a 150 shot.
64 Tempest wagon .060 455 96dports UD RAIV 112lsa 3.23 gears 4000lbs with driver 12.85@104 on motor, 11.32@119 on 180 shot
http://www.youtube.com/watch?v=XGf_pe66mOE http://www.youtube.com/watch?v=obtS3SlbE6Y |
1967 GTO E head 467. 3000lbs best time old motor 9.33 @144 200shot spray only in 3rd gear.
New AllPontiac motor installation In Progress Last edited by bryansMtngto; 05-31-2011 at 10:21 AM. Reason: added thought |
Roll around in the excitement |
2900 lbs, 8-71 on a 8% nitro mix. Slowest 60-foot ET of the weekend. (was in the 1.00s 60-foot the prior test passes that weekend).
1963 Tempest Convertible Pontiac-Powered Funny Car: 400 block, Littlefield 8-71 blower, Enderle injection, custom blower intake, three-disc glide clutch, three-speed Lenco |
Test and tune prior to the Saturday Night Nitro event at Famoso. No. 7 hole out the entire pass (checking into an intermittent points box issue)
Vin63, what does the car weight?
400 Pontiac block, cool! |
With the funny car body, it weighs around 3300 lbs with me in it.
Great job, Vince. It inspires me to keep at it with my Tempest. Too many irons in the fire!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Mike Bright Special thanks to Mark Luhn at Luhn Performance for all the help |
Post #30 says 2900#???
Because this is how the car was configured at that Pontiac Heaven/Nostalgic Show-n-Go event…note that the car was run as an altered - no funny car body.
http://www.youtube.com/watch?v=8wUn82-L3Lo
1963 Tempest Convertible Pontiac-Powered Funny Car: 400 block, Littlefield 8-71 blower, Enderle injection, custom blower intake, three-disc glide clutch, three-speed Lenco Last edited by vin63; 12-27-2013 at 12:03 PM. |
| The Following 2 Users Say Thank You to vin63 For This Useful Post: | ||
#38
King of the stock blocks IMO... until recently Vin was also running an N crank from a 400 too... with RPM over 8500 and Nitro. Truly impressive... Most calculators show power at these weights well in excess of Vins stated power numbers.
I applaud him for taking the path few would follow! |
| The Following 2 Users Say Thank You to BruceWilkie For This Useful Post: | ||
#39
Update - 6.60 at 215
#40
ET? Many ten-second full-pulls...
Yeah, it's only for 300 feet- but haulin' 14,000 pounds of transfer sled! ![]() MPH? Too bad tire speed doesn't count for much- about 110 in this photo, 123 with the hemi.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
