Old 03-24-2010, 02:05 AM
lust4speed's Avatar
Don't think I agree with that - You can still have a lean idle with a big cam. You are correct that very rich conditions will dilute the oil, but a rich idle isn't a given parameter of a tight lobed cam with a large overlap. I'm sure that there are a bunch of engines out there that fall all over themselves because of a lousy tune, but they also really sound unhealthy. A true ground pounder tuned correctly creates vibrations clear into your soul.
Mick Batson
Old 03-24-2010, 05:01 AM
goatman65's Avatar
They didn't chain it down or even chock the wheels, I've run my cars before on a chassis dyno and we had it chained and blocked. Nice car and the cam sounds fine to me, 65 is my favorite year. I've owned 2 hardtops and a convertible.
Actually it was strapped in the front and rear.
Old 03-24-2010, 05:15 AM
goatman65's Avatar
Originally Posted by old66tiger View Post
What did it make on the dyno?
[email protected]'t remember the tq off hand but it was less than 500.I was expecting more from this size engine and cam.And more rpm.Not much of a power curve either,more like straight up then back down.
Old 03-24-2010, 06:18 AM
ta man ta man is offline
Run your 290b with 1.65 rockers with a set of SD KRE 290cfm heads you will have same idle more or less with high ten potential.Get some due on here to run a duno simulation....I forget what it is but I'm sure it is in the 550 to 600 hp range at around 6000rpm depending on rocker ratio.
Old 03-24-2010, 06:37 AM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
My mistake, I guess I didn't see it in the video. I didn't think anyone would chance it though.
Anyway like I said nice car and I hope to have another 65 someday myself.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-24-2010, 11:12 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Originally Posted by john5670 View Post
I think a lot of people love the sound of a nasty, rough idle cam. But what causes this? In most cases your air and fuel are not properly mixing. This is fine and expected if you have a drag car that creates its power at high RPMs. I think its important to find that balance though for a street car. A rough idle creates cylinder wash at low RPMs until the motor start reaching the proper mixture. Cylinder wash will cause premature engine ware and poor street ability. My 2 cents is find the right balance between sound, power, and longevity.
i dont think thats altogether right??? sure that causes a nasty idle so does unplugging a vacuum line, i think those cause the other nasty idle. theres plenty of cammed street cars running around without that problem, i think it really depends on how obnoxious a cam you cal tolerate on the street
Old 03-24-2010, 01:05 PM
lust4speed's Avatar
My mistake, I guess I didn't see it in the video. I didn't think anyone would chance it though....
The first roll was just to center the car up on the rollers since the car came in a little off center.
I wonder if the two-roller dyno unit had anything to do with torque being down compared to horsepower? The old Clayton dyno's had a hard time with wheel spin due to the small rollers and it wasn't unusual to have three guys sitting in the trunk during the run to provide extra traction. Could you post the results?
Mick Batson
Old 03-24-2010, 04:49 PM
mudbird's Avatar
mudbird mudbird is offline
Ditto lust "clear to your soul"
MudBird
Old 03-24-2010, 10:50 PM
john5670 john5670 is offline
A properly tuned engine that has a rough idle does not have the correct fuel and air mixture at low RPMs. The rough idle is cause by poor burning of the air fuel mixture. If you cause your car to run rough to look like you have a lot of horse power, your foolish. Your giving up what your trying to advertise. Yes there are plenty of large cam street cars running around, but if they are not properly tuned to have the correct air/fuel mixture for the used power range, its only a matter of time before they need to be rebuilt. It may be 2,000, 10,000 or 50,000 miles. It won't be the optimal engine life though. Ask a reputable engine builder. I would be surprised if he recommends a poor tuned engine for a cool sound.
Old 03-25-2010, 12:19 AM
im no professional but, theres alot more to the rough idle than just bad a/f ratio. sure if i take a stock 400 with stock cam and fatten up the tune for a nastier sounding idle it would be foolish, but if i take that same 400 put a lil bigger lopier cam in, after fine tuning it is still gonna have a rough idle and it wont having anything to do with air mixture it will be more due to the reversion caused by the bigger cams duration and overlap. as long as you use the right gears and converter the only real sacrafice poor life expectancy of tires poor gas mileage, and some times it could get to be a pain to drive if you were gonna try and drive it all the time. the only thing that i really see being a factor of how long will the motor last is, most people with these types of motors dont just wussy foot around in them, they run the piss out of them
Old 03-25-2010, 08:38 AM
Like I said, it needs to be properly tuned to have the correct air/fuel ratio. I am not saying all large cams are bad. I have a 462 stroker with 585 hp at 6000 RPMs. It has a very large cam for a street car. I am only suggesting to the member that he does not sacrifice longevity for a cool sound. As long as he can maintain the correct air/fuel ratio for the RPM range that is used the most he is good to go. As far has him dirving the piss out of the car. That is hard to do when you are cruising the highway at 75 mph. A lot of damage can be done even at cruising speeds if you do not tune the engine correctly. Although there are many contributers to a rough idle, a poor tune should never be one of them. Why put thousands into a motor for poor performance.
Old 03-25-2010, 09:00 AM
When guys say they have a large or big cam they always refer to duration it seems.My car has large lift for a street cam in the .650's but smaller duration compared to many at around a 230/240 @.050.I wouldn't say it has a nasty idle as in rough but it sure trumpets out the back especially if its idling in park.
Old 03-25-2010, 10:28 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
IMHO The car sounds great with the 290b cam! Your not going to change the impression of the average person by trying to make the idle rougher. What does an engine with the Comp 300b sound like? I think thats the part #, the one bigger in the catalog. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 03-25-2010, 07:31 PM
goatman65's Avatar
I wouldn't run the engine improperly tuned for the sake of a rough,racy idle.Performance comes first,if it sounds like a 10 sec car then it has to be able to back it up.
Old 03-25-2010, 09:21 PM
screamingchief's Avatar
screamingchief screamingchief is offline
On the chassis dyno my engine peaked at 4900 rpm,397rwhp,then nosedived.
397 @ 4900.Don't remember the tq off hand but it was less than 500.I was expecting more from this size engine and cam.And more rpm.Not much of a power curve either,more like straight up then back down.
Exactly what valve springs are you using on those 6X heads?
What pushrods??
Stud girdle???
The 290b6 should pull strong to 6000+ no problemo.
Also,was that cam degreed when it was installed?
With the 6X heads and the compression your running,you really dont wanna go any bigger than that 290b6 cam.
Also,what sorta exhaust are you running,tight LSA cams absolutely abhor restrictive exhaust tracts,a restrictive exhaust system can cost big chunks of power with the tight LSA cams.
Can be lots of reasons for what your seeing,just gotta work thru the usual suspects in a logical way to eliminate any & all possible issues,it's a process,and it can be tedious at times,but you gotta expect to put in some work to reap the gains.
As for a SR cam to replicate the 290b6 when you upgrade the heads,here's my choice:
Brand & part no.:Comp custom high tech .420" SR lobes #51-000-5
Grind & lobe no.: AKA: the 290b6 roller "clone" cam. ( lobe # 4009/4023)
Tappet type: Solid Roller Tappet
Spec = intake/exhaust: (notes)
Adv.duration = 290°/304° (I/E split = 14°) (note: rated @ .020")
Dur. @ .050" = 254°/266° (I/E split = 12°)
Dur. @ .200" = 171°/180° (I/E split = 9°)
Lobe lift = .420"
Lift @ 1.5 rr = .630"/.630" (Gross lift) (To get Net lift subtract lash below)
Lash =
106° LSA = 106° ICL = 106° ECL
Seat events:
IO = 39° BTDC
IC = 71° ABDC
EO = 78° BBDC
EC = 46° ATDC
OL = 85°
Events @ .050":
IO = 21° BTDC
IC = 53° ABDC
EO = 59° BBDC
EC = 27° ATDC
OL = 48°
Compare that to the 290b6:
Brand & part no.: Comp Cams Part no.51-659-5 . (catalog grind)
Grind & lobe no.: Grind no.290b6 (lobe #6061/#6013)
Tappet type: Solid Flat Tappet
Adv.Duration = 290°/304° (I/E split 14°) (note: rated @ .020")
Dur. @ .050" = 255°/266° (I/E split 11°)
Dur. @ .200" = 160°/172° (I/E split 12°)
Lobe lift = .360"/.356"
Lift @ 1.5 rr = .540"/.534" (Gross lift) (For Net lift subtract lash)
Lash = .026"/.028"
LSA = 106° ICL = 106° ECL = 106°
Seat events:
IO = 39° BTDC
IC = 71° ABDC
EO = 78° BBDC
EC = 46° ATDC
Total O/L = 85°
.050" events:
IO = 21.5° BTDC
IC = 53.5° ABDC
EO = 59° BBDC
EC = 27° ATDC
O/L @ .050" = 48.5°
Does'nt get any better/closer than that!
What's the diffence you ask???
Look at the additional lobe lift and the .200" duration numbers and you'll see.
And that SR cam will absolutely love better flowing heads!!!
But I'd definitely work with the current combo some more before making that leap.
Sooner or later though,those trips wont be able to keep up.
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 03-26-2010, 05:58 PM
goatman65's Avatar
What pushrods??
Stud girdle???
Lobe lift = .420"
Lash =
Seat events:
IO = 39° BTDC
IC = 71° ABDC
EO = 78° BBDC
EC = 46° ATDC
OL = 85°
Events @ .050":
IO = 21° BTDC
IC = 53° ABDC
EO = 59° BBDC
EC = 27° ATDC
OL = 48°
Lash = .026"/.028"
Seat events:
IO = 39° BTDC
IC = 71° ABDC
EO = 78° BBDC
EC = 46° ATDC
Total O/L = 85°
.050" events:
IO = 21.5° BTDC
IC = 53.5° ABDC
EO = 59° BBDC
EC = 27° ATDC
O/L @ .050" = 48.5°
Bret P.
Springs are comp #995.130 closed,334open @ .550
Pioneer pshrods 5/16.I cant find the length.I had to get longer than stock because the lifter plunger was down in the body further than on the comp lifters that i was using with previous cam.
No stud girdle.Comp guide plates,7/16 studs.
Cam was not degreed.I'm suspecting this 'could be' a contributing factor.I run an E-brock geardrive with a 3 keyway crank gear.VERY hard to see the lightly stamped markings for +4,-4 or 0.There is a good chance i might have used the wrong keyway and installed it 'retarded' *4.
It does pull to 6000 and beyond with no problem,it just stops making power at 4900.
I'm replacing my 1-5/8 headers with 1-3/4.
I run 6x heads to keep a 'stock' look and i didn't have money at the time for alum.heads.I think to get low 11s/hi 10's the KRE heads would help a lot.
Old 03-26-2010, 07:00 PM
Steve C. Steve C. is online now
Jim LeHart (Mr P-body) has had very good sucess with the 290-b solid flat tappet cam. His recipie in 6X-8 heads with Comp Magnum 1.65 rockers is 150 seat pressure at 1.600" installed height, 340 lbs open. Valve size, 2.110"-5.095" long.
A fwiw, if and when the time comes and you change push rods and are using 5/16" upgrade to a thicker wall section rather than the typical .080"-.083" diameter. Manton 0.118" wall is a good one. Also Smith Brothers.
  #38
I thought your deal sounded familiar,so I went digging thru the archives last night after working on my race car,and yeah we talked about all this like last fall.
Absolutely power lurking in that exhaust IMO.
IIRC my suggestion was for headers with bigger primaries,I believe I suggested 1 7/8" with 3.5" collectors as what I would prefer to see on there,but agree going to the 1 3/4" x 3" headers is better than what you have.
I'm gonna be using 1 3/4" x 3" headers (hedman) on the 400 for my '70 Lemans/GTO race car with a very similar custon Crower solid cam (hell the back-up engine I'm building for that engine has a 290b6 ready for it),and even with what,50 some less cid I feel that size header is marginal @ best,the only saving grace to my situation is what exhaust there is will be 3" all the way back to the dumps in front of the rear axle.
And yeah,I'll bet $$$ that your cam is installed advanced,probably quite a bit.
And I'd put some stiffer pushrods in there,the pioneers are likely .065" wall,and I feel .080" wall chro-moly is the minimum,and the .118" wall pushrods are even better.
I'd also think long and hard about adding the stud girdle too.
Most combos like yours with solid cams like that peak right around or just over 5500 RPM.
Also,the chassis dyno sheet you posted showed it was a mustang dyno,and I have heard thru the grapevine that those can give hit or miss results for some,but somebody else like Harry K. would probably know a lot more about that than I do.
Oh yeah,the rwtrq was much healthier than the hp that was for sure,I think that was like 486 peak lb/ft @ the wheels,and something like 390 lb/ft average on the best run.
So that too makes me think the cam is installed advanced past what's recommended as well.
The KRE heads are always a worthy consideration when looking for more power than stock heads are typically gonna make,I'd get 'em thru SD if I were looking to buy,those guys do real good work.
Gotta go,finishing up my ignition panel installation/mock-up in the race car,and I'm burning daylight,then I shift to messing around in the garage working on misc. stuff for either my '72 firebird street car,or my brothers '68 S code 390/C-6 Ranchero GT.
Bret P.
  #39
Old 03-26-2010, 07:07 PM
goatman65's Avatar
Thanks.Yes you have answered the same questions a few times for me.I WILL degree the cam,even if its 'on' at least i will have eliminated that as a problem.Not sure if i can fit headers bigger than 1-3/4,my 1-5/8 are tight in places.
I will call SD for heads.
  #40
Old 03-26-2010, 08:08 PM
You would be suprised how much better the big tube headers can fit on some cars.
Though often one tube on each side gets re-routed around/over a frame rail to make that happen,and the primary tubes themselves are a "slip fit" into the collector,also these sorta headers typically use a sub-flange on the head that repositions the flange bolts,so that inturn eliminates the hassle of trying to get to "that bolt".
Most folks that use these sorta headers swear they'll never go back to the "traditional" style of headers.
I'd likely be talking to Mark @ maddog myself.
HTH
Bret P.
