thats the one.
thanks 68gtomn for helping patrick
68gtoMN thanks for the scan, but I do have a copy of that resto guide, I just am a little unclear on where the rear bracket attaches to the block as I am missing the threaded stud it bolts to. If someone could put a pic of the rear area of compressor and block it would be a great help. |
the rear bracket attaches to the cylender head bolt that has a stud on top. It is the same type of bolt that the battery ground atteches to on the drivers side. Look at your bolts to see if someone in the past installed that bolt in the wrong place. If so just swap them out. Re torque to specs.
Hope this helps a little bit more. I believe it bolts to the center head bolt. (between the exhaust ports) patrick
Thanks for the diagram. Looks like I am missing the pivot bracket for my A/C compressor.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. ![]() |
The bolt with the threaded stud was installed on the front pass side and after I installed the pivot bracket I didn't notice it there. Swapped em around and retorqued. Last edited by Ozzmann; 10-15-2010 at 01:25 AM. |
![]() ps is Mark Webber going to hang on and win the F1 drivers title? patrick
