Old 10-19-2010, 03:29 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
What brand of lifter? How does the lifter surface look?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 10-19-2010, 03:39 PM
sisco sisco is offline
I dont know what brand. On the build sheet it just said, drilled flat tappet solid lifter. Its pretty crushed to pieces
Old 10-19-2010, 04:09 PM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
I saw this with a socket once. Somebody must have dropped it into the motor when assembling and figured "it'll be OK, its in the sump". Ran for a while before it got itself between the pan and a rod coming down and punched out through the bottom of the pan. Upside, apart from a new pan it was OK.
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
Old 10-19-2010, 04:26 PM
What happened is in the number 3 cylinder the solid lifter somehow ended up in the pan where the crank hit and pushed it through. I dont know what could have caused it to do that or how its even possible. I did notice the engine seemed alittle loud up top even for a solid lifter engine when I got it.
Old 10-19-2010, 04:31 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Did a push rod bend and the lifter get pushed out the top or did the lifter break to pieces?
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 10-19-2010, 05:49 PM
67bonnie455 67bonnie455 is offline
Default Rocker nut
A rocker nut lock can back off allowing the rocker arm to loosen up. Once it unhooks the rocker from the push rod, the cam knocks the lifter out of the bore like home run ball. The push rod is probably wrapped around the crank. See if the rocker adjuster is loose on the missing lifter.
It will loose oil pressure with the missing lifter. Check the bearings and look at the piston skirts and undersides for damage from a lifter pin ball bouncing around the rotating assembly. Make sure the valve did not fall. If there is metal shavings in the pan (from a tore up push rod), you need to clean the oil gallies and put in a new pump. You may have very little damager other than the pan.
Old 10-19-2010, 07:25 PM
The lifter is in pieces in the oil pan. The rods are bend to where I cant pull them out and the rockers are loose.
Old 10-19-2010, 07:59 PM
steve's Avatar
steve steve is offline
I have a feeling this will get ugly when the engine builder is approached.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 10-19-2010, 09:56 PM
Default Valves/springs
The adjuster nuts are loose or the rockers are loose? Bent push rods will cause the loose rockers. I was trying to learn if a loose adjuster caused the problem, but if you have several bent push rods, you likely have a valve train geometry problem.
What heads do you have? The short valves on the LM 6X/5C must run springs with very short minimum bind height like 1.00 or less. Often the "pockets" need to be cut to get the spring height correct and or longer valves. With a sold cam, you probably have a lot of lift. That would cause the bent push rods and broken valve springs.
IMO, the oil gallies need to re-cleaned. If the oil filter bypass opens, the metal pieces end up in the gallies and will damage the rebuild. Often over looked.
PM me the builder, I would like to know.
Sorry to hear about your motor problems.
Old 10-20-2010, 01:39 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
IIRC when I ran my 70 GTO at Piedmont Dragway there was a "Sisco" on the board in that area. Are you that person? If so PM me.Highly unlikely that an engine builder will stand behind his work if performed more that a year ago, regardless of mileage.
Old 10-20-2010, 03:54 PM
Well got the engine back to the builder today. It looks like from a glance the block and all is ok. Hes checking it all out thoroughly but it sounded promising. The best news of all said hed fix it. There still are some good folks around in this industry. Looking forward to getting the bad blue Ventura back together. Thanks to all for the help
Old 10-20-2010, 04:11 PM
Sounds like a good builder. It bites that you have to go through all of the time and expense to deal with the problem, but anyone can have problem with a motor. Let him have a chance to make it right. That separates the good builders from the bad ones. At our Pontiac dealership, I saw a few defective new motors and transmissions over the years.
Definitely not the guy I was thinking of.
Best of luck!
Old 10-20-2010, 04:37 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Not that this is related, but my buddy's Chevy the rocker lock nut split. Caused about the same issues. The engine had to be completly torn down, and redone. Parts wise was not that bad, but they re turned the crank and that led to new bearings, new cam, lifters, etc. Not knowing what was bent in the damage. The valve did not fall though, he got lucky.
He went roller after that.
........I'm just learning as I go.......
Old 10-21-2010, 01:03 AM
Leftyarmstrong Leftyarmstrong is offline
Tell your builder he gets a standing O from this group!
1965 Pontiac Lemans Convertible, 1957 Chevy 3600 dump bed, 1968 Ford backhoe.
http://picasaweb.google.com/orchidsk...vyiKGThcblmQE#
