Old 07-28-2011, 08:35 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by RA1John View Post
FWIW...
Have the same drawing/pix for the 2nd style (short) Hood Tach on a '68 Firebird Hood and the hole size, location is different.
By any chance, can you post the 2nd style template mentioned above?
Will Rivera
Old 07-31-2011, 01:56 PM
FunctionalShaker FunctionalShaker is offline
Here's a pic of the diagram from the 69 assembly manual. Copy isn't very good, but you can make out most of the measurements. Interesting that it calls for three screw holes.
Name:	69 Tach Dia.jpg
Old 08-01-2011, 11:20 PM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
Here's a photo I took of a 67 Firebird to use as a reference when I install my tach.
Name:	67 Hood Tach.jpg
Old 11-04-2025, 09:48 AM
Frank's 69 Firebird 400 Frank's 69 Firebird 400 is offline
Would anyone have a factory template for a Hood Tach on a 1969 Firebird 400 Coupe? I want to make sure before drilling a hole in my hood the exact factory location for the Hood Tach.
Old 11-04-2025, 01:32 PM
Originally Posted by pontiac_banshee View Post
[email protected]
I have a template to. The problem is the guy (shop) that did mine didnt hvae the correct hole saw so instead of asking me if he could buy one he used a 1/4" larger saw. Yah, he had the instructions from the manufacturer but now I am stuck so want to see how bad it is.
Would you have the Template for the 1969 Hood Tach Installation?
Old 11-04-2025, 03:03 PM
If you have the assembly manual, I believe the info you need is in there. I'm at work, so I can't verify.
Old 11-04-2025, 03:06 PM
I just saw the old posts, after replying. Does the assy. manual info. not work for you?
